mikael82 Report post Posted June 19, 2018 (other forum is having difficulties, so I move my thread from there to here) This is my car; 1992, so called "ibrid" car. I have bought it years ago, but because huge car tax in my country, only last year I was able to drive this car for first time after three years in garage, when car reached 25-years of age. I will post some resently posted stuff here. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 So it starts... Well time to time anyway. Thing is for all my ownership, which I have not driven car so much starter is stucking "on" what I think is from clutch dust not letting starter gear to return. So engine has to come out so I can see it. Yes, if starter needs to come out engine has to come out. It starts by clearing much of the stuff out, exhaust, cooling pipes, part of chassi, few tubes and some sockets. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Fluids coming out. by experience I know with these cars you need to have desent size pucket where to drain them, although Diablo "only" got 14 liters motor oil. I suspect gearbox oil and diff oil has not come out for some time, maybe in last centuary... Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Gear lever asembly needs to come out, it come out underneath. As you can see, rubber supports are looking bad outside, usually they are good inside, but they are so cheap to change as you are there... Driveshafts needs to detach from engine. Last time right side driveshaft was forgot to torque... it was loose, but did not "pop" open like they should. This how I lift car up. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 What I desided to do was pull out clutch slave cylinder from engine without bleeding fluid. Compleat system is new from few years ago, so it was easy to remove when I grease it properly and fluid is fresh anyway. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 I had to extend my engine lift, regular "chinese" engine hoist does not reach. But engine comes out. I left wire loom on engine, found it much easier. 180cm is quite long. And there it is. Not so pad to take out, easier then Ferrari BB/Testarossa engine, all hoses are better located in Lamborghini. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 And to reach issue in hand: heatshield out and starter out. and here is what is wrong, after all it was not pinion; Stupid Bosch solenoid does not move at all! THis is issue with solenoid; dry grease what was washed away and solenoid mover freely. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Starter disasembly: Remove grease cup and remove loking washer Two nuts out and note there are shims under loking washer. Unbolt solenoid fork rod. Slide casing open: With two nuts, remove long rod studs that are bolted. Slide motorshaft out and this is important; Fork needs to be exactly this way as in picture, note that form of fork is different on each side. To remove bendix gear, remove lock washer as in picture. ...and there is starter on table. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Pulling gearbox to see if there needs to be seals changed and how clutch is looking. Gearbox come out when you remove clutch leaver, mark it before you do. Clutch looks pretty good, very clean and seems to have much surface, I have spare change set, but I do not change clutch, I will not even open it. Att least one clutch have being changed, but I have when mechanics leave parts dirty... No leaks, I am not going to change any seals this time. Engine comes out easy, so no big deal. ...So I washed gearbox with Pineline (pine oil soap) that is very efective and does not remove zink. Couple of pictures from gearbox. Do note that it is VT gearbox casing, but without front wheel drive. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 I removed engine electrical harnes, I made mistake to remove plenum and oil catch can seperately, they need to come out same time. Middle of block is pool of old washers, dirt and water. Not a leak from engine. I washed middle of block and outside of engine with pineline. sparyer for soap and other one for water. There is engine number, mine is #1019 Engine version is "L 522" THis is 19th VT engine, they started next generation of engine from number "1000" , first one of these "ibrid" cars is "12834" Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 You need size 50mm hex tool for those spark plug bolts, yes I have socket for those in my garage. Distributor and phase sensor got 180 degree "change" to go wrong. 48-valves... that is seriously lot of them. Cam cover gaskets did not leak, except from ends and small amount to sparkplug, what was caused by too little torque on their bolts. Chain is tight, I got VT engine, so it is double. It have not even touch upper guide on valve cover, have to how lower ones look. What is causing oil leak, is o-ring att end plates, all of them, are flat. THey must be original, because they are re-used with silicone. Those o-rings are not in pre VT-engines, they have regular flat gasket, might work better. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Starter motor assembly highlights after cleaning ans re-grease; hard part with it is to get front lock ring back on, this is best method I could think of. How to get brushes in is set bolts to hold them in while you slide rotor through. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Cam cover paint was pealing off, so I power jet washed them, it was one of those Kärcher machines with hot water. Nailed them to asfalt with board and this is how much I removed only with water. Enginebay needs to get washed, so pushed car out and shielded most of important ports. And it was dusty, note how paint in heatshields comes of only with washing. So I washed rest off with paint thinner and gave fresh coat of aluminium paint. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Diablo kind of got two engines together, because of engine managment and this car had run out of balance because not so many know how to balance them, there can be difference between side if balance is out. This side there is dry mist inside plenum. This side there is oil breath tube coming in and oil have cumulated in. I gave them clean up. Nice to see, that intake trumpets, are polished. There was odd aluminium shim under there, it did not open gasget, but didn't seat cover correctly, I re-shimmed cover Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Driveshafts are leaking grease, not widely all over like if boot would be broken, but between flange and CV-joint. I washed hubs clean. Issue with CV-joint is copper washer between there, it is one use only and if driveshafts are removed, they should be replaced, or attleast heated. This one in picture got spread and from there missaligned. I did not find correct Löbro washer, but lukily Porsche 911 got cheaper paper version that will fit. Local Porsche service guy did not even know what it was, when I asked hem to retrive me "four more" Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted June 19, 2018 Next level. Congrats. Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Thanks. Getting closer to present situaton; Valve clearance is good to check, when engine is out and since there was leak from cover ends. 3 shims where changed to other place and needen four new ones mostly +.05 I bended couple of screwdrivers to get sims out, after poping vacuum out under them, pulled out with magnet. Sims are same with Ferrari four valve engines and because we do not have Lamborghini dealer in my country (my car is only coupe and then there are two roadsters) , I bouought them from Ferrari. 13€/each Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted June 19, 2018 Thanks for sharing. What part of Finland? Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 19, 2018 Thanks for sharing. What part of Finland? South, near Helsinki Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted June 19, 2018 Love the thread, great work. Quote Share this post Link to post Share on other sites More sharing options...
megachad Report post Posted June 19, 2018 wow!! awesome.. nice car too! Quote Share this post Link to post Share on other sites More sharing options...
abolfaz Report post Posted June 20, 2018 Well done! Quote Share this post Link to post Share on other sites More sharing options...
Double Report post Posted June 20, 2018 Good show, 'Mate. Obliged for the write-up, and the pix. Cheers. Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted June 20, 2018 South, near Helsinki Cool! My fiancee has family that have places in Helsinki and Turku I think it's called. I was there about 2 years ago. Very nice place! Quote Share this post Link to post Share on other sites More sharing options...
mikael82 Report post Posted June 20, 2018 Cool! My fiancee has family that have places in Helsinki and Turku I think it's called. I was there about 2 years ago. Very nice place! I am on east side of Helsinki, but visit Turku for sports car event that is every year week before midsommer (last weekend) People might not be as happy or friendly what you are used to, but I think famous metal band sums it right in their lyrics (translated) "In this cold country where winter is long and summer is included" Also it is said that when mankind will send people to Mars, they should be Finns, because we are totally fine to sit in small dark room in silence sorounded everlasting cold and darkness, not seeing sunlight through small windows for months after another, no need to say any word to anyone else in room for days, no need to small talk, would not care to know name for peolpe next to you and be totally fine without to ask "how are you?" and suspect anyone who does that for reason for this guestion... Quote Share this post Link to post Share on other sites More sharing options...
