Allan-Herbie Report post Posted July 20, 2018 Any suggestions on a good steamer that can be used to clean undercarriages, engine etc? Thanks! Quote Share this post Link to post Share on other sites More sharing options...
NRG x Lambo Report post Posted July 20, 2018 I'll try to find the brand, but there's an attachment you can put on a pressure washer that shoots water upward specifically for undercarriages. Almost like a car bidet. LOL. Quote Share this post Link to post Share on other sites More sharing options...
IanMan Report post Posted July 20, 2018 I'll try to find the brand, but there's an attachment you can put on a pressure washer that shoots water upward specifically for undercarriages. Almost like a car bidet. LOL. THIS ^ This is really convenient. Especially here in the winter. It's also in a spread configuration instead of a single direct jet and has wheels on it for easy access. Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted July 20, 2018 I hear Cleveland makes a really good one. Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted July 20, 2018 I hear Cleveland makes a really good one. Quote Share this post Link to post Share on other sites More sharing options...
360challenge Report post Posted July 20, 2018 you may want to look into Cryo detailing. It uses dry ice under pressure and cleans chassis, engines without any disassembly. The results are quite impressive. i just saw a 964 done by TUNE RS in coral springs, Fl. they have a video on the process. Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted July 20, 2018 Are you opposed to gas powered? Electric pressure washers are generally shit, but might be adequate for light duty work. Something like this is about your best bet if it needs to be electric. https://www.amazon.com/dp/B00LX8Z03K/ref=as...da0bb72d086abe6 If you want something with some real balls that can power a foam cannon, gas is the way to go. All the 'attachments' are typically focused around gas powered stuff. Brand of the thing isn't critical, just get a Honda or Brigs & Stratton motor and preferably a CAT pump. Sherwin Williams paint stores actually have some REALLY nice pressure washers, much better than what you'll find at home depot in about the same price range. Don't buy a low end gas unit, you'll just want to blow it up in the desert after a week of frustration and problems. Quote Share this post Link to post Share on other sites More sharing options...
darth sidious Report post Posted July 20, 2018 Karcher Readily available in the UK. Searched Karcher USA and found this:- So presumably also available across the pond. Quote Share this post Link to post Share on other sites More sharing options...
NRG x Lambo Report post Posted July 20, 2018 Quote Share this post Link to post Share on other sites More sharing options...
cake Report post Posted July 20, 2018 We bought a Broutech Undercarriage /Drive way Washing Broom Cleaner Set with Interchangeable Nozzles 4000 PSI W/36 inch Extention Wand & Wheel Angle Promptly return it. Poor quality. The description was inadequate in that it didn’t specify you need a pressure washer with 4000 psi capability (they changed the title/description in response to my comments on why we were returning it). A friend had his RS America cryo-cleaned and loved the result. It doesn’t harm rubber trim, gaskets, engine components etc. He is borderline OCD (or maybe fully OCD) and was thrilled with the result. I think he used http://cryogenesis-usa.com/ in Elyria, OH Quote Share this post Link to post Share on other sites More sharing options...
porter Report post Posted July 21, 2018 I hear Cleveland makes a really good one. Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted July 22, 2018 Thanks guys but I want a steamer, not a pressure cleaner. Quote Share this post Link to post Share on other sites More sharing options...
