PCJR Report post Posted November 17, 2016 Does anyone here have any pictures with these springs installed on an Aventador? Please share if you do. Thx! Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted December 23, 2016 Looking for a set of installation instructions if anyone can get their hands on a set. Quote Share this post Link to post Share on other sites More sharing options...
NRG x Lambo Report post Posted December 24, 2016 Looking for a set of installation instructions if anyone can get their hands on a set. have you tried reaching out to novitec themselves? Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted December 24, 2016 have you tried reaching out to novitec themselves? Yes spoke to someone there about it but he said he'd get back to me...nothing all week. Quote Share this post Link to post Share on other sites More sharing options...
SAMLAMBO Report post Posted August 13, 2017 Any updates? Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 13, 2017 Any updates? Sold the car already. I did get a set of instructions also. The odd thing is that the collar that goes over the stock rear shock was too small in diameter once the dealer took it apart. So at this point I have the complete set of springs which are brand new but unsure if they are correct. Part numbers are correct so not sure what to do with them at this point. I also have the front and rear wheel spacers and longer wheel bolts If anybody is interested?? 11MM width per wheel and looked great on the car. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 13, 2017 Can't you just adjust the stock coilovers to lower the car? Quote Share this post Link to post Share on other sites More sharing options...
SAMLAMBO Report post Posted August 14, 2017 Sold the car already. I did get a set of instructions also. The odd thing is that the collar that goes over the stock rear shock was too small in diameter once the dealer took it apart. So at this point I have the complete set of springs which are brand new but unsure if they are correct. Part numbers are correct so not sure what to do with them at this point. I also have the front and rear wheel spacers and longer wheel bolts If anybody is interested?? 11MM width per wheel and looked great on the car. If I knew for sure it would fit I wouldn't mind taking them of u Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 16, 2017 Can't you just adjust the stock coilovers to lower the car? The rear is no problem as it has a fair amount of adjustment. it's the front which can only be adjusted down about 7-8mm. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 16, 2017 The rear is no problem as it has a fair amount of adjustment. it's the front which can only be adjusted down about 7-8mm. Thanks for the info. Quote Share this post Link to post Share on other sites More sharing options...
henry47 Report post Posted August 20, 2017 The rear is no problem as it has a fair amount of adjustment. it's the front which can only be adjusted down about 7-8mm. is this DIY-able with simple tools and a spanner wrench like on the gallardo or is it really labor intensive? i remembered lowering the gallardo only took 2-3 hours of my time. would love to be able to do this on my aventador. Quote Share this post Link to post Share on other sites More sharing options...
henry47 Report post Posted August 22, 2017 The rear is no problem as it has a fair amount of adjustment. it's the front which can only be adjusted down about 7-8mm. Is there any more info you can give me on lowering the stock suspension? I'd like to give it a shot pretty soon. Any help is appreciated! Thanks Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 22, 2017 If the Aventador coilovers work like every other car (and they should) loosen the lower perch to elongate the spring and it will lower the car. Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 22, 2017 If the Aventador coilovers work like every other car (and they should) loosen the lower perch to elongate the spring and it will lower the car. Yes the shocks/struts have the typical threaded body like any other coilover. I'll reach out to the tech that worked on it to ask him I'll reply back. Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 29, 2017 Yes the shocks/struts have the typical threaded body like any other coilover. I'll reach out to the tech that worked on it to ask him I'll reply back. Ok spoke to the tech that worked on mine. He used an XL pair of pliers to loosen the locking nut on the fronts. For the rears he used this: Quote Share this post Link to post Share on other sites More sharing options...
henry47 Report post Posted August 29, 2017 Ok spoke to the tech that worked on mine. He used an XL pair of pliers to loosen the locking nut on the fronts. For the rears he used this: awesome! thanks so much! do you remember how long it took for him to complete the adjustment? Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 29, 2017 awesome! thanks so much! do you remember how long it took for him to complete the adjustment? The adjustment time is not long at all, maybe two hrs max to adjust and check heights. The rears are easily accessible it's the fronts that are a pia. I removed the front trunk liner which took a little time to figure out. Going back in was much easier. I am going to advertise the Novitec wheel spacers & lug kit if anyone is interested. It definitely competes the look! My car picture attached, lowered with spacers. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 29, 2017 Your car looks perfect. Quote Share this post Link to post Share on other sites More sharing options...
sl55 Report post Posted August 29, 2017 SV with Novitech 1" drop... Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted August 29, 2017 Your car looks perfect. It was thx. It went to a great home in southern Illinois. Quote Share this post Link to post Share on other sites More sharing options...
SSR Report post Posted September 24, 2017 The Novi springs are softer than SV ? Novi has a special part number for SV or they are the same for normal AV ? Quote Share this post Link to post Share on other sites More sharing options...
