Capristo Exhaust !
James@SPE
Hello Lambopower! I am here to introduce Capristo exhaust systems although I am aware most of you do not need an introduction. All systems for the Lamborghini market are made with 309 stainless, mandrel bent, and hand welded. These guys have been in the game for over twenty years and for obvious reasons. Great quality matched with a wonderful sound is what we expect from an exhaust purchase. This is what Capristo offers and so we at SP Engineering are happy to deal them.
Payment can be made to us with CC over the phone (626)333-5398 or via Paypal at [email protected].
Shipping is for Lower 48 only. Canada add $5.00 ! :badgrin:
Aventador LP700 Exhaust - $7000 shipped
Includes remote to permanantly open or close the valves, else will make use of a vacuum setup that will adjust the valves depending on driving conditions.
Aventador LP700 Test Pipes - $1700 Shipped
Will bolt up to OEM headers and 02 sensors can be re-installed without issue.
Diablo Exhaust - $5600 Shipped
Bolt on application that is guaranteed to not set off any CEL lights like other exhaust on the market. This exhaust is valveless.
04-08 Gallardo - $5350 shipped (+700 for valve tronic remote)
This system makes use of the OE vacuum system for the valves. The ECU will control the valve system just as it does on the stock system. It has the option of a remote for an additional $700 which will allow for control over the valve system.
LP-550/60/70 Exhaust - $5700 shipped
This exhaust, like the 04-08 Gallardo, makes use of the OE valve system which are reused in this system. It has the option of using a remote system to control the valves to be open or closed at all times for an additional $700.
Invalid Video Link
Murcielago Exhaust - $6300 shipped
This exhaust makes use of the OE vacuum system for the valves. There is an option for a remote to control the valves to stay open or closed at all times for an additional $700.
Murcielago Black Billet Tail Piece - $1900 shipped
These look badass ~~
Murcielago LP640 Complete Exhaust System - $18,700 shipped
Includes:
Valve Exhaust System
Set of high performance headers
Secondary cat delete pipes
200 Cells High performance Sports Catalytic Converters
Standard Exhaust Remote Control Kit + Lamborghini plugs
The CAPRISTO® system does not have any restrictive factory exhaust sound regulations, and was engineered and designed to let the howl of the Murcielago's redline to be heard by all with the distinctive CAPRISTO® sound...
The CAPRISTO®'s high performance headers use a 4 into 1 style collector which gives more horsepower higher in the high rpm range, and which gives a better spread of power and our sports cat are 200 cells providing a much better flow with less restrictions compare to the OEM ones.
By installing a CAPRISTO System, you will not only improve dramatically the sound of your vehicle, but you will also be able to get the power in the rpm range where you would normally drive the car. It is also noted that very few people drive their road vehicles at max rpm at all times and for "every day" application.
Like our other high performance exhausts, the complete Mucielago high performance system is intended to be a balanced increase between power, drive ability and sound quality, without forgetting of course a substantial loss of weight.
EXHAUST:
The CAPRISTO® Valve-controlled exhaust system for the Lamborghini Murcielago is designed for accurate fitting to the original connections and is completely made from from T309 grade stainless steel.
MANIFOLD:
The manifolds work on the "4 in 2 in 1" principle, and are made entirely from T309 grade stainless steel . They feature a significantly changed pipe routing compared with the stock manifolds. These manifolds fit on the original mounting points and a replacement of the original manifold can be carried out without any problems.
Murcielago LP640 Exhaust ( No headers ) $12,200 shipped
Murcielago LP640 Valve Exhaust System + 200 Cel Cats + Remote
CAPRISTO® introduces this performance package for the Murcielago LP640 which includes:
Twin Sound Valve Exhaust System
Test Pipes (includes O2 simulator)
Programmable Remote
