kzsport Report post Posted September 6, 2011 Hi Guys Quick posting CEL below this. 1.P1311 2.P1426 3.P0151 4.P0157 05' Gallardo e-gear 31K miles The vehicle was fuel full and oil service done.had aftermarket exhaust with. Also 1-5,6-10 engine light on after start 2-3 mins. ABS on and lifting light flash all the time.check the P/S liquid was okey. Need the opinions plz Thanks alot Brian Quote Share this post Link to post Share on other sites More sharing options...
colorinc Report post Posted September 7, 2011 i looked up your codes in the manual clip4.tiff clip_3.tiff clip2.tiff clip_1.tiff Quote Share this post Link to post Share on other sites More sharing options...
kzsport Report post Posted September 8, 2011 i looked up your codes in the manual Thanks for your input bud. Brian Quote Share this post Link to post Share on other sites More sharing options...
rosso spyder Report post Posted October 14, 2011 i had a 1-5 CEL in my 07 spyder once. It was condensation that had collected in the engine misfire tubes. Had the tubes replaced & new clamps installed also exhaust sensor threw it I believe. Was covered under extended warranty...after a song and a dance. Supposedly a common problem with gallardo btw. Quote Share this post Link to post Share on other sites More sharing options...
kzsport Report post Posted November 19, 2011 Final,I'd find out one spot of ground had bad contact that on RH rear frame and located on under rear cover panel. After rewire and reconnect no CEL and start like usual as before. Quote Share this post Link to post Share on other sites More sharing options...
