Monty Report post Posted December 31, 2009 Hello I have had today a very big problem on my gallardo, egear don´t work, I have checked fuses. If I take 12V to the E-gear pump change works properly so I supose it is a fuse or a relay, anyone has some document so I could Know what fuse and relays are?? I have seen some relays and fuses back, and also in the right side but no one was blown. Pump is working ok but onl y if I take 12 v to it. Very thanks, any help will be appreciated. Sorry my English. Quote Share this post Link to post Share on other sites More sharing options...
joebiz Report post Posted December 31, 2009 Monty- take a look at this thread for some help. Perhaps a similar problem. What year is your car? http://www.lambopower.com/forum/index.php?showtopic=45193 Please reply with the solution that you find. Thank you and good luck! Quote Share this post Link to post Share on other sites More sharing options...
Monty Report post Posted December 31, 2009 Monty- take a look at this thread for some help. Perhaps a similar problem. What year is your car? http://www.lambopower.com/forum/index.php?showtopic=45193 Please reply with the solution that you find. Thank you and good luck! Thanks for the help, but my problem is I could not gear select, no gear at all, because e-gear pump dont work, but it really works when you put direct 12v in the pump, so only could be a fuse or relay problem I think, but I would check all the grounds by the way. It would be very interesting Know what is the E-gear pump relay with only this info , it will be very easy to find the problem. Quote Share this post Link to post Share on other sites More sharing options...
