sprite Report post Posted June 2, 2010 Got my G Spyder today. However, towards the end of the day the top started acting up. It refused to lock when opening it. Then trying to close it again it only got to about the halfway point. I ran it back and forth about fives times before it finally locked it top down position. When closing it got stuck halfway again, I hit the button again and it closed fully. Now it says Soft top cannot be used in the display when I am trying to use it. I am guessing the system is detecting some sort of problem. Going to take it to Lambo tomorrow. Car is under warranty so not a big deal, just annoying. Was wondering if anyone else had a similar issue? Quote Share this post Link to post Share on other sites More sharing options...
jstrat85 Report post Posted June 2, 2010 dam sprite sorry to here that. ill bet you its nothing. car looks sick! Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 Seems to be working fine again now. I read somewhere the top is voltage sensitive. Maybe my battery is a bit low. Will see if it acts up tomorrow. Quote Share this post Link to post Share on other sites More sharing options...
djantlive Report post Posted June 2, 2010 it could be also something simple as hydrolic fluid level. make sure it's full and car is on levelled ground instead of incline/decline. Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 Checked the hydraulic fluid. It is full. Quote Share this post Link to post Share on other sites More sharing options...
UH-Matt Report post Posted June 2, 2010 Doing it with engine running or not? Could have been voltage if car was not started and running? Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 Doing it with engine running or not? Could have been voltage if car was not started and running? No engine was running. Quote Share this post Link to post Share on other sites More sharing options...
Scotty Report post Posted June 2, 2010 I had a similar problem once, it cleared and has not happened since. Voltage idea sounds reasonable. Quote Share this post Link to post Share on other sites More sharing options...
SV-N-IT Report post Posted June 2, 2010 when is she going to heffs? ive had mine for 4 years and never had this issue. def bring it to Lambo. Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted June 2, 2010 Most of the soft top problems I have heard of were due to one or more of the limit switches not making contact properly. It's a easy, inexpensive fix if that is the case. Hot car, BTW!! Nice! Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 Most of the soft top problems I have heard of were due to one or more of the limit switches not making contact properly. It's a easy, inexpensive fix if that is the case. Hot car, BTW!! Nice! That would make sense if it turns out to be an intermittent problem. Hopefully I will get it sorted quickly if it keeps occurring. Quote Share this post Link to post Share on other sites More sharing options...
AJGlobal Report post Posted June 2, 2010 I've never had any issues either. Shouldn't matter if the car is running or not. I've opened it and closed it both ways several times with no issues. Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 Seems to be working fine now. If it happens again I will just take it to Lamborghini, car has warranty until February 2011. Initial impression is that this car is better than my F430 Spider in every possible way. Power, handling, looks, build quality, etc. Quote Share this post Link to post Share on other sites More sharing options...
toplesswhitegal Report post Posted June 2, 2010 The top operation is sensitive to power, you can operate the top with the engine off but only on a fully charged battery. Once the battery does go low it will post an error on the dash indicating that the top cannot be operated, then start the car and the way you go. I have had a Spyder for 3 years so I have seen it a few times as I have dropped the top many times with the engine off. I did have one failure with a limit switch, according to the dealer the limit switch was part of the hydraulic ram so it needed replaced. Quote Share this post Link to post Share on other sites More sharing options...
Blackberry Report post Posted June 2, 2010 Nice car! Post up some more pics for your LP brothers Quote Share this post Link to post Share on other sites More sharing options...
SV-N-IT Report post Posted June 2, 2010 Nice car! Post up some more pics for your LP brothers what are the mods planned? Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted June 2, 2010 what are the mods planned? Nothing too fancy. Just painting rims black and doing verde calipers for now. Quote Share this post Link to post Share on other sites More sharing options...
SXN Report post Posted May 6, 2016 Sorry to bring up an old thread, but where do you check the hydraulic fluid? Thanks Quote Share this post Link to post Share on other sites More sharing options...
