FikseSTS Report post Posted November 24, 2010 Where are the ports to recharge AC in Gallardo? thanks! Quote Share this post Link to post Share on other sites More sharing options...
rampante Report post Posted November 24, 2010 I believe they are underneath the trunk liner near the right front side. Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted November 24, 2010 I believe they are underneath the trunk liner near the right front side. Negative. Under the car (I want to say drivers side rear) you will see a small triangular aluminum plate held in by three Torx screws. Remove this plate and you will see the AC ports. Keep in mind these are not the standard AC charging ports that USA cars use (which are a male AN style port) - These are female ports. Pretty sure all the 04-08s use 134a refrigerant, too. Good luck! Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted November 24, 2010 Here... Quote Share this post Link to post Share on other sites More sharing options...
FikseSTS Report post Posted November 24, 2010 thank you very much! so I need adapters to hook up these refills that are bought at the auto store? Here... Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted November 24, 2010 thank you very much! so I need adapters to hook up these refills that are bought at the auto store? I think so...I've never done it, so I can't advise...But I know they are different than most US cars. Quote Share this post Link to post Share on other sites More sharing options...
deonss Report post Posted November 24, 2010 I think so...I've never done it, so I can't advise...But I know they are different than most US cars. Might be the same as an Audi. Just a thought. Quote Share this post Link to post Share on other sites More sharing options...
turbotoo Report post Posted August 31, 2014 Might be the same as an Audi. Just a thought. Thanks for the info... Quote Share this post Link to post Share on other sites More sharing options...
CA_SL65 Report post Posted August 31, 2014 Deleted Quote Share this post Link to post Share on other sites More sharing options...
