LamboJoe Report post Posted June 12, 2013 My brother's 640 would not shift, the mechanic said it's the potentiometer is this an engine out job ? 30 hours labor really ? Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted June 12, 2013 Unfortunately, yes. It's a cheap part, but engine out to replace. In the Gallardo you can reach them without dropping the engine. Good time to change the clutch as the engine is dropped. Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted June 12, 2013 Unfortunately, yes. It's a cheap part, but engine out to replace. In the Gallardo you can reach them without dropping the engine. Good time to change the clutch as the engine is dropped. Just wonder do you need to drop the engine if u goin to change a murcie clutch? Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted June 12, 2013 Just wonder do you need to drop the engine if u goin to change a murcie clutch? This has been discussed extensively and the general consensus is, yes. Quote Share this post Link to post Share on other sites More sharing options...
LamboJoe Report post Posted June 13, 2013 so basically it's the only way to do this job is to drop the engine. Quote Share this post Link to post Share on other sites More sharing options...
git54ty Report post Posted June 14, 2013 What does a potentiometer do? Quote Share this post Link to post Share on other sites More sharing options...
Nath4N Report post Posted June 14, 2013 What does a potentiometer do? http://lmgtfy.com/?q=potentiometer Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted June 14, 2013 Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted June 14, 2013 What does a potentiometer do? The potentiometer are for egear to keep track of where the shift shafts are so it knows where each gear is at. One is for forward and backward and one is for side to side. Same a replacing a clutch the engine/gear box must be removed. The labor time is a bit high for the job. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted June 14, 2013 All the e-gear stuff sits on top of the transmission. Hence the required engine/trans drop. Quote Share this post Link to post Share on other sites More sharing options...
LamboJoe Report post Posted June 15, 2013 The potentiometer are for egear to keep track of where the shift shafts are so it knows where each gear is at. One is for forward and backward and one is for side to side. Same a replacing a clutch the engine/gear box must be removed. The labor time is a bit high for the job. he will be lucky if he gets $80 an hour after I'm done with him. Quote Share this post Link to post Share on other sites More sharing options...
djantlive Report post Posted June 15, 2013 Did ur mechanic have a Lambo computer and concluded this using the computer with a transmission error code? Often, egear failure are due to other issues. How is you battery voltage? Egear fluid level? These are the simple things to check first. Does the egear prime when door is opened? Quote Share this post Link to post Share on other sites More sharing options...
LamboJoe Report post Posted June 16, 2013 Did ur mechanic have a Lambo computer and concluded this using the computer with a transmission error code? Often, egear failure are due to other issues. How is you battery voltage? Egear fluid level? These are the simple things to check first. Does the egear prime when door is opened? Battery in 3 weeks old, fluid is good, e-gear pump is good, when you open the door it does not prime when the door open's. Quote Share this post Link to post Share on other sites More sharing options...
djantlive Report post Posted June 16, 2013 If it isn't priming, I don't think it's the potentiometer. You should check voltage, even new battery left not drive can discharge Quote Share this post Link to post Share on other sites More sharing options...
Frank-Goodson Report post Posted June 22, 2013 E-gear parts and labor are all high! Quote Share this post Link to post Share on other sites More sharing options...
