MKS Report post Posted June 26, 2017 Huracan stage 3 are crazy... They are running 211+ I need one here in Kuwait Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 26, 2017 Thank you! I like all your cars! Thank you Leo and can't wait to see you at TI Quote Share this post Link to post Share on other sites More sharing options...
LeoMiami Report post Posted June 26, 2017 Thank you Leo and can't wait to see you at TI I'm looking forward my friend 👍🏼 Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted June 26, 2017 Wow 5000rpms you sure that late on a v10 V6, V8, V10 makes absolutely no difference at all. It's displacement and RPM. And when you have an 8500 RPM redline, 5k for full boost isn't bad at all. Quote Share this post Link to post Share on other sites More sharing options...
PCJR Report post Posted June 26, 2017 Is Stage 3 with race heads available with DCT on Huracan now? The UGR page says "Coming Soon". Check "Houston T" - Peters thread here. Quote Share this post Link to post Share on other sites More sharing options...
dustinb1985 Report post Posted June 26, 2017 I would go with Stage 3+ w/ race heads. It's the only way to go! I thought for a while about not sending mine to UR for TT when it arrives... Then I realized how bored I would get after a month of driving it lol. It comes in November and it's going straight to NC (Blu Cepheus) Can't wait to see that bad boy! My fav color. You guys make me wanna rob a bank!! Lol Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 26, 2017 V6, V8, V10 makes absolutely no difference at all. It's displacement and RPM. And when you have an 8500 RPM redline, 5k for full boost isn't bad at all. Yes cuz usually the v10's have double the displacement therefore they spool earlier Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted June 26, 2017 Yes cuz usually the v10's have double the displacement... No, they definitely do not. Quote Share this post Link to post Share on other sites More sharing options...
Tslicc Report post Posted June 26, 2017 Displacement definantly effects spool, for example, a GTR with a 3.8L equiped with 67mm turbos won't hit full boost until close to 6000rpms, even some cases after 6000. Increase the displacement to a 4.1L or a 4.4L, it would hit full boost somewhere between 5000-5500rpms. Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted June 26, 2017 Displacement definantly effects spool, for example, a GTR with a 3.8L equiped with 67mm turbos won't hit full boost until close to 6000rpms, even some cases after 6000. Increase the displacement to a 4.1L or a 4.4L, it would hit full boost somewhere between 5000-5500rpms. Obviously. Number of cylinders means nothing in that equation. Quote Share this post Link to post Share on other sites More sharing options...
Tslicc Report post Posted June 26, 2017 Obviously. Number of cylinders means nothing in that equation. No cylinders are irreverent when it come to spool Quote Share this post Link to post Share on other sites More sharing options...
ibglobal Report post Posted June 26, 2017 Based of the other cars you have might as well go all out.. I see the pattern Quote Share this post Link to post Share on other sites More sharing options...
duhawks Report post Posted June 26, 2017 By stage 3 he means stage 3x Quote Share this post Link to post Share on other sites More sharing options...
VentadorGER Report post Posted June 26, 2017 By stage 3 he means stage 3x You mean XXX Billet Unicorn Stage. That one oes not come with a warranty....but with a race winning guaranty Quote Share this post Link to post Share on other sites More sharing options...
dirty Report post Posted June 27, 2017 By stage 3 he means stage 3x I said 3+++++ Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 27, 2017 Obviously. Number of cylinders means nothing in that equation. The v10 has a 5.2L and the previous had a 5.0 so yes that's more spool and displacement is not the only factor there's the dynamic and static compression and fuel type like ethanol which can early the spool too Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 27, 2017 I said 3+++++ Hahaha Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 27, 2017 No, they definitely do not. Ok Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted June 27, 2017 Sounds really really good can't wait Hi MKS, speak to kevin about stage 3 with race heads running 62 mm turbos. I have these on my LP stage 3 with raceheads and power comes on at 4000 rpm. I also make 1275rwhp with MS109. your stage 3 will be very track friendly running on pump gas on lowest setting with 800rwhp, I can assure you. If you take a brave pill you can track at 1150rwhp on pump. Only 'disadvantage' of the smaller turbos on stage 3 is that you cannot upgrade to 1R. To go to a 1R you do need the 67's plus billet manifold and billet gearbox etc. From one of Kevins recent posts, I believe he favours the 1R as the ultimate UR street version. You can always use the lowest boost setting and be very streetable. Leo is certainly a fan of the 1 R and I know Leo will never argue about not having enough power!!! just my two cents worth after street and strip driving my stage 3 after 25,000 miles (40,000kms). Whatever you choose, kevin and the team will see you right. cheers, john Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 27, 2017 Hi MKS, speak to kevin about stage 3 with race heads running 62 mm turbos. I have these on my LP stage 3 with raceheads and power comes on at 4000 rpm. I also make 1275rwhp with MS109. your stage 3 will be very track friendly running on pump gas on lowest setting with 800rwhp, I can assure you. If you take a brave pill you can track at 1150rwhp on pump. Only 'disadvantage' of the smaller turbos on stage 3 is that you cannot upgrade to 1R. To go to a 1R you do need the 67's plus billet manifold and billet gearbox etc. From one of Kevins recent posts, I believe he favours the 1R as the ultimate UR street version. You can always use the lowest boost setting and be very streetable. Leo is certainly a fan of the 1 R and I know Leo will never argue about not having enough power!!! just my two cents worth after street and strip driving my stage 3 after 25,000 miles (40,000kms). Whatever you choose, kevin and the team will see you right. cheers, john Thank you sir 👍 Quote Share this post Link to post Share on other sites More sharing options...
duhawks Report post Posted June 28, 2017 Thank you sir 👍 I drove my 2R like 6,000 miles or something on the street lol! These DCT cars would be even better on the street and every day use! It was so fun I drove it every where! Quote Share this post Link to post Share on other sites More sharing options...
MKS Report post Posted June 28, 2017 I drove my 2R like 6,000 miles or something on the street lol! These DCT cars would be even better on the street and every day use! It was so fun I drove it every where! Yeah I did the same with my 1R it drove better than stock and sounded a lot nicer too Quote Share this post Link to post Share on other sites More sharing options...
need4spd Report post Posted June 28, 2017 with these stage 3 kits and 1r what power do you get if you don't use ice for the heat exchanger? I think i heard somewhere that you will get timing pulled if the temps are too high without ice. Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted June 28, 2017 with these stage 3 kits and 1r what power do you get if you don't use ice for the heat exchanger? I think i heard somewhere that you will get timing pulled if the temps are too high without ice. Hi need4speed, Kevin would be the best person to answer this. I know from my limited experience of 25 sprints or so that logically, icing the reservoir resulting in lower inlet air temps should give more power. UR would not go to the trouble of making a lovely intercooler reservoir with provision for icing, if icing was not of benefit. Frankly, I personally have not been able to 'feel' the difference as don't have vbox. The 'butt dyno' is not known for accuracy when you are hanging onto the steering wheel under full acceleration, I give you the big tip-eek! but vbox would tell you. I have found that for me picking the right rpm to change up in the lower gears so as to get onto max boost in 3rd gear and up as fast as possible is most critical for a good Vmax. just my two cents worth. cheers, john Quote Share this post Link to post Share on other sites More sharing options...
LeoMiami Report post Posted June 28, 2017 Leo is certainly a fan of the 1 R and I know Leo will never argue about not having enough power!!! just my two cents worth after street and strip driving my stage 3 after 25,000 miles (40,000kms). Whatever you choose, kevin and the team will see you right. cheers, john 1R is A killer packeage IMO Quote Share this post Link to post Share on other sites More sharing options...
