Stimpy Report post Posted June 25, 2018 Posting for a friend that can't create an account on here due to the issue with the Captcha: fellow murciemen and women, need your help. was driving my 09 yesterday and drove it for about 10 miles when it decided to die on me. luckily i pulled into a parking lot. had to get it towed home- battery shows power- i also recharged it overnight and same result. car ignition comes on, it tries to turnover but is not able to. any advice? thanks Share this post Link to post Share on other sites
megachad Report post Posted June 25, 2018 Try a new battery anyways. I believe murci’s have a bus fuse by thw on off switch. That may be corroded. Check for good connectivity with starter etc. Share this post Link to post Share on other sites
MrEd Report post Posted June 25, 2018 Yeah, never hurts to throw a new battery in and certainly check the fuses. It is in Neutral right? Sometimes when they get weak, they can't shift to Neutral themselves to start. Share this post Link to post Share on other sites
Powerr95 Report post Posted June 25, 2018 thanks so much stimpy- finally am able to get on to the site- sent the car over to get it checked out. will keep everyone posted. stimpy, i owe you big time for your support. what a true person, he was there for me at 1030 at night and through out the weekend. I OWE YOU. Share this post Link to post Share on other sites
yellomurci Report post Posted June 25, 2018 When you say "tries to turn over but cant" do you mean the starter engages the engine and it moves but not enough to crank or do you mean it seems as the engine is seized? When it died did it come to a stop with the engine turning or did it lock up? would still be best to put a new battery in and try as that has worked on many strange situations in a murcy. Share this post Link to post Share on other sites
Powerr95 Report post Posted June 28, 2018 sorry maybe the wrong verbiage- its trying to turnover but does not seem like its getting gas or something. thanks guys, i sent it to a local shop in Houston that knows these cars so waiting to see what they figure out. so far they have changed the battery and no luck, then they ordered a part which will take 5 days to get here but they are not sure if this will fix the situation. are these cars just a mystery or something? keep your ideas coming! last time my buddy had a problem with his lp, i found the answer on the forum and told him and he went and told the dealer that was fixing it and thats how the dealer figured it out!! Share this post Link to post Share on other sites
FastCars Report post Posted July 9, 2018 Any updates? Hopefully it was nothing major. Share this post Link to post Share on other sites
michaelpua Report post Posted July 11, 2018 Did the diagnostics turn up any "pending" error? Could be the phase sensors problem. When they fail, the ECU will cut all ignition and that's like total fuel cutoff instantly (not gradually). Share this post Link to post Share on other sites
Powerr95 Report post Posted July 12, 2018 thanks to all that chimed in to help. the issue was the crankshaft position sensor. the problem is fixed but a new one appeared. the srs light is on and it was not on before this issue. they reset it and it came back. lord have murcie. any ideas? for the bill i get to find out tomorrow so lets see how bad it is Share this post Link to post Share on other sites
JonV8944s Report post Posted July 30, 2018 thanks to all that chimed in to help. the issue was the crankshaft position sensor. the problem is fixed but a new one appeared. the srs light is on and it was not on before this issue. they reset it and it came back. lord have murcie. any ideas? for the bill i get to find out tomorrow so lets see how bad it is Aka, the airbag. The Murcielagos have weak 'clock springs' in the steering wheel that provides the contact to the airbag, if someone tried to adjust the steering wheel while the car was 'on' or 'running' that brief break in continuity in the airbag connection when the telecoping steering wheel is moved/adjusted sets a code, that can ONLY be removed with a TRUE Lamborghini diagnostic computer with the airbag module wire. Ask me how I know... lol... LITTERALLY HOURS BEFORE I sold my 2006 Murcielago, I had the NEW owner test driving the car, and I said 'lets adjust the steering wheel to your likeing' Car was running... SRS light triggered, and he looked at me like 'whats wrong with this car' lol.... fortunately I swore to him it had never happened before, and that I'd call my lambo tech (official one), and the lambo tech not only diagnosed the problem but also helped us to resolve it (since obviously he has the real computer), and 2 years later, and the problem has never reoccurred. IF YOU ARE GOING TO MAKE STEERING WHEEL ADJUSTMENTS, DO THEM WHEN THE CAR IS OFF !!!! (You may not have made the adjustment, but the shop you took it into may have) Share this post Link to post Share on other sites
Stimpy Report post Posted July 30, 2018 if someone tried to adjust the steering wheel while the car was 'on' or 'running' that brief break in continuity in the airbag connection when the telecoping steering wheel is moved/adjusted sets a code, that can ONLY be removed with a TRUE Lamborghini diagnostic computer with the airbag module wire. I had the light come on recently, and an independent here in Houston with the "Galileo" system was able to turn the airbag light off. So you don't need the official system to do that. Share this post Link to post Share on other sites
ExoticCarDriver Report post Posted July 31, 2018 thanks to all that chimed in to help. the issue was the crankshaft position sensor. the problem is fixed but a new one appeared. the srs light is on and it was not on before this issue. they reset it and it came back. lord have murcie. any ideas? for the bill i get to find out tomorrow so lets see how bad it is Hi. I am showing the OBD fault code for the crankshaft position sensor is P0336. I am just curious was a check engine light displayed for this code? Was the fault diagnosed via an OBD II reader? Share this post Link to post Share on other sites
whiteout Report post Posted July 31, 2018 Aka, the airbag. The Murcielagos have weak 'clock springs' in the steering wheel that provides the contact to the airbag, if someone tried to adjust the steering wheel while the car was 'on' or 'running' that brief break in continuity in the airbag connection when the telecoping steering wheel is moved/adjusted sets a code, that can ONLY be removed with a TRUE Lamborghini diagnostic computer with the airbag module wire. Ask me how I know... lol... LITTERALLY HOURS BEFORE I sold my 2006 Murcielago, I had the NEW owner test driving the car, and I said 'lets adjust the steering wheel to your likeing' Car was running... SRS light triggered, and he looked at me like 'whats wrong with this car' lol.... fortunately I swore to him it had never happened before, and that I'd call my lambo tech (official one), and the lambo tech not only diagnosed the problem but also helped us to resolve it (since obviously he has the real computer), and 2 years later, and the problem has never reoccurred. IF YOU ARE GOING TO MAKE STEERING WHEEL ADJUSTMENTS, DO THEM WHEN THE CAR IS OFF !!!! (You may not have made the adjustment, but the shop you took it into may have) This. Share this post Link to post Share on other sites
