SV-N-IT
Final Perf spyder pics promised!
Congrats! Car looks Amazing!!! I just got my coupe delivered yesterday and I’m estatic so I know exactly how you are feeling.Good luck and enjoy! Love that color!
thank you so much guys once again! :)
professional shots coming asap!
I actually like the soft top, very well insulated and lightning quick to go up or down up to 30mph!
im 5,10 and I fit well, but if you are over 6,1 this is not the car for you FYI
Have you had the springs installed? Any feedback on the ride?
thanks again guys/girls!!!!!!!!!!!!! :)
springs are just about as cushy as the factory spring.
have to watch pot holes, get skid plates, and have dealer install cause front lift has to be recalibrated FYI
Great info, where do you get skid plates?
Does it sit a lot lower than factory ?
If the lift doesn't work correctly at all times, it's the same issue I had, and a recalibration won't work. It'll only cost you money for nothing.
Car is sitting too low and you just need to fool it into thinking it's higher than it really is.
I purchased a set of adjustable sensor arm links...and adjusted them to get to 5mm shorter than the stock sensor arms. It's a very common issue in many cars with adjustable ride height and / or lift systems. Most Huracans don't have the issue, but you get the odd one that does, like mine did.
The links are available at only one store...and are very inexpensive @ 125.00 for the pair. It took longer to get the car on the lift than it did to change them. It was like 2 minutes / side to remove the old links and install the new ones. They snap on and off. Have your dealer do it to be safe.
You can get them at http://www.ghostmotorsports.com and speak to Alex...he has a few sets left for the Huracan. They are beautifully made and very high quality....they will never give out on you. These links are pretty much all they do there...
This is what they look like (these are not the ones for your car)
https://www.ghostmotorsports.com/product-pa...ghostlinks-q74l
He doesn't have the Lambo links online, but if you call him, he will ship them fast!
This is my car after the spring change --
Congratulations and love the spec!
FUCKIN PERFECT SPEC man! Way to knock one out of the park.
The Blu Lemans with Gold wheels and black accents is just sooo right.
Enjoy it in good health!
