Fabspeed_Motorsport Report post Posted December 19, 2018 Are you looking to take the leash off your Huracan? Fabspeed’s premium stainless steel Valvetronic Supersport X-Pipe replaces the factory muffler and outlet pipes for an outstanding upgrade in sound, allowing for two distinct exhaust tones depending on the position; mild and wild. This system also significantly reduces weight, saving 23 lbs. while adding over 29 whp and 19 ft-lbs of torque compared to the OEM exhaust system! The factory exhaust on the Lamborghini Huracan is a very heavy, very restrictive system. The muffler is comprised of multiple chambers, filled with perforated tubing, wool packing, and a set of secondary catalytic converters. The exhaust gas must force its way through all of this in order to exit the system, which robs the car of considerable power. Fabspeed's unique valve design provides two very distinct sound modes when using the factory steering wheel mounted mode selector. In Strada mode, the valves on the 70mm bypass pipes remain closed, channeling the exhaust gases through Fabspeed's signature 63.5mm quad-resonated x-pipe, producing a smooth and sophisticated exhaust note ideal for cruising around town and on long stretches of highway. Switch the car into Corsa mode, and prepare to have your world rocked. In Corsa mode, the valves open up, allowing the exhaust gases to rocket straight out through the 70mm bypass pipes with a snarling aggressive scream. The full fury of the Lamborghini V10 is unleashed, along with an intoxicating and menacing barrage of pops and crackles upon deceleration and downshifting. We utilize the best valves in the business: Helical Technology. They have extensive experience in high-volume OEM automotive applications has led to standard features such as an extremely durable pneumatic actuator, precision flat sealing faces inside the valve, stiffening ribs and high-temperature bearings at both ends of the butterfly spindle. These are the only valves trusted by the world’s top car manufacturers like Lamborghini themselves, as well as Porsche and Ferrari. This system truly needs to be heard and felt to be appreciated. Check out the video and below and let me know what you guys think! https://youtu.be/bP5ymYyQ8hA We also offer this out the valve set up! Email me for LAMBOPOWER pricing [email protected]! Quote Share this post Link to post Share on other sites More sharing options...
