Allan-Herbie Report post Posted April 19, 2019 I know you can flash the ECU's on the the 13+ Aventadors to SV specs, does anyone know if you can do them now to SVJ specs? Quote Share this post Link to post Share on other sites More sharing options...
RDW Report post Posted May 3, 2019 Oh wow, seriously..it's just a ecu flash for the increases on the SV & SVJ? My 2016 might like that to happen if it real.... Quote Share this post Link to post Share on other sites More sharing options...
VCR Report post Posted May 4, 2019 I highly doubt that. The SV is based on the 1st-gen AV so an ECU flash to SV specs is possible since the hardware is more or less the same. The SVJ is based on the AV-S/2nd-gen AV where they added another mode to the transmission and the car has 4WS; the hardware is somewhat different. So perhaps it's possible from the AV-S to the SVJ spec. 1st-gen AV to SVJ spec would seem unlikely. Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted May 7, 2019 On 5/3/2019 at 5:34 PM, VCR said: I highly doubt that. The SV is based on the 1st-gen AV so an ECU flash to SV specs is possible since the hardware is more or less the same. The SVJ is based on the AV-S/2nd-gen AV where they added another mode to the transmission and the car has 4WS; the hardware is somewhat different. So perhaps it's possible from the AV-S to the SVJ spec. 1st-gen AV to SVJ spec would seem unlikely. You may still be able to flash the motor. So far from seeing the results I think the fastest Aventadors may be the regular bodied editions, with updated tunes. Quote Share this post Link to post Share on other sites More sharing options...
topjay Report post Posted May 7, 2019 Talking to a couple of factory engineers recently who were saying all engines basically the same and that they all run 800+ and are then detuned from there Quote Share this post Link to post Share on other sites More sharing options...
VCR Report post Posted May 7, 2019 1 hour ago, Allan-Herbie said: You may still be able to flash the motor. So far from seeing the results I think the fastest Aventadors may be the regular bodied editions, with updated tunes. If they can flash the motor part only, that would be great. I'm concerned that the entire system "talks" to one another and when some parts want to talk to the 4WS module, it's not there. Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted May 8, 2019 8 hours ago, VCR said: If they can flash the motor part only, that would be great. I'm concerned that the entire system "talks" to one another and when some parts want to talk to the 4WS module, it's not there. I think the TCU only picks up speed signals from the Ecu in order to shift the car in areas like auto mode. The TCU handles all the transmissions functions. Quote Share this post Link to post Share on other sites More sharing options...
