chucklehead Report post Posted July 5, 2019 Need to get new Min switch for front lift, 2004 Murcielago. Has anyone tried generic pressure switches? PVL website. 41 B/C diaphragm pressure switch. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted July 5, 2019 If it has the same specs, it should work. You can bet Lambo used an off the shelf part. How much is that switch? If it's inexpensive enough, it's worth the gamble. Quote Share this post Link to post Share on other sites More sharing options...
chucklehead Report post Posted July 5, 2019 I may give it a try. 15.51 pounds plus VAT 18.61 see if they ship to USA. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted July 5, 2019 You won't pay VAT if you are having it shipped to the US. At least make sure they don't charge you VAT. Quote Share this post Link to post Share on other sites More sharing options...
chucklehead Report post Posted July 5, 2019 Here’s one from a store in US. Barksdale CSK switch Quote Share this post Link to post Share on other sites More sharing options...
chucklehead Report post Posted July 6, 2019 Purchasing above switch for MIN. Has the connectors, 1/4 NPT, normally open, can set for >20 bar. getting Barksdale CSK 15-21-12B for MAX switch. Normally closed, 700-1900 psi. They are about $35 a piece. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted July 6, 2019 Huge savings over the factory units, if they work out as a replacement. The Murci world will thank you forever if you pull it off! Quote Share this post Link to post Share on other sites More sharing options...
Dereiter Report post Posted July 6, 2019 Great information. Thanks. Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted July 6, 2019 Are these a common failure part? Let us know how they work out. Quote Share this post Link to post Share on other sites More sharing options...
chucklehead Report post Posted July 6, 2019 2 hours ago, sprite said: Are these a common failure part? Let us know how they work out. Seems like they fail fairly often. On my car, the front lift was raising then coming immediately down with front lift light flashing. This was a MIN switch failure. Quote Share this post Link to post Share on other sites More sharing options...
V12noise Report post Posted July 7, 2019 Can anyone say exactly what the spec needs to be to mimic the Lambo switches, e.g. normally closed at 0 psi and opens at 1200psi, or normally open at 0psi and closes at 100psi, etc for the Min and the Max switches? I dont have a clear picture in my head of which switches are needed... Quote Share this post Link to post Share on other sites More sharing options...
V12noise Report post Posted July 10, 2019 On 7/7/2019 at 9:36 AM, V12noise said: Can anyone say exactly what the spec needs to be to mimic the Lambo switches, e.g. normally closed at 0 psi and opens at 1200psi, or normally open at 0psi and closes at 100psi, etc for the Min and the Max switches? I dont have a clear picture in my head of which switches are needed... So nobody knows what they're buying.....? Quote Share this post Link to post Share on other sites More sharing options...
Destructo Report post Posted July 10, 2019 Does anyone make a Chilton style manual for the Lamborghini's? I remember using those for domestics when I was younger, but never thought to ask or look if they make them for the Italians. Quote Share this post Link to post Share on other sites More sharing options...
chucklehead Report post Posted July 17, 2019 For the MIN switch, normally open. Close when it gets more than 250 psi. Don’t know exact number. Figure that’s why front lift light blinks when you hit a bump. MAX switch, normally closed. Opens when above 1400 psi, so it knows when it is fully raised. Quote Share this post Link to post Share on other sites More sharing options...
V12noise Report post Posted July 18, 2019 15 hours ago, chucklehead said: For the MIN switch, normally open. Close when it gets more than 250 psi. Don’t know exact number. Figure that’s why front lift light blinks when you hit a bump. MAX switch, normally closed. Opens when above 1400 psi, so it knows when it is fully raised. Great, thanks for the explanation. Quote Share this post Link to post Share on other sites More sharing options...
