door speaker screen cover
frank7746
Gentlemen,
2005 Murcielago coupe
I had to take the door panel off to change a mirror.
Everything went fine and all back together except I can't get the speaker cover to go on correctly.
Does the cover go between the rubber and the outer metal ring or inside the rubber?
Any advice on how to get it on?
Thank you
Frank
The trick is to pull the rubber gasket out from the metal trim ring, put the gasket around the speaker grill and then insert it into the metal ring.
