Help—Alarm Issue
My 2005 Murcie Roadster—Last three times with both doors n engine bay closed, each time I turn the key on half way to get the power on (starting sequence), it instantly triggered the siren alarm even before I press the unlock button to start the car.
Once I remove the key from the ignition, press the unlock button to stop the alarm (it stops) then re-insert the key back into the ignition, the car started up perfectly as it should.
I recently replaced the battery key fob right before this started so I’m not sure if it was a catalyst...Appreciate your shared thoughts and/or advice. Thanks
