ttSam Report post Posted August 20, 2022 Thanks for checking this question out guys , Issue: when ignition is turned to position 1 or engine is started, all needles on all gauges (excluding Tach and speedometer )start to sweep very slowly from zero position to max position in Unisom. this takes takes 10 to 15 minutes. The Tach needle sweeps quickly to the past max position and stays there. Speedometer does nothing, and does nor work when driving. if ignition is switched off and on again, needles resume where the left off, tach sweeps again. if ignition switched off for an hour or so, the needles will start from zero positions again. everything in the car is working. Its a 2002 Murcielago with 6 speed. Checked so far: all fuses replaced battery reset gauges as per post on lambotalk checked grounds and cleaned. removed cluster to check connections visually, including disconnecting and reconnecting. work done around the time this happened; tried led brake light bulbs but they were flashing so re installed oem cleaning of area around front lift block Thanks insrument panel issue.mp4 Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted August 25, 2022 There must be a place that rebuilds these . Quote Share this post Link to post Share on other sites More sharing options...
ttSam Report post Posted September 2, 2022 Please do let me know if a place to rebuild these is recommended. thanks Quote Share this post Link to post Share on other sites More sharing options...
