Juju
Engine & Check engine light
Has i explain in my precedent topic (new owner), i already have a " little " issue with my Murci.
I put here this new topic. You can put Inside your experience with those dash light (engine & check engine L R light). Hope it doesn't exist (didn't found one)
Is spoke with a specialist, apparently it could come from a cylinder  because of a dirty valve causes malfunction cylinder (i'm not a Professional, but this is what i understand)
It would be a known problem and very easily repaired.
I will be able to confirm soon, i see the guy tomorrow.
So, diag test gave his results. It is the gaz filtering system that would have a slight leak. It will be fixed at the end of the season. ...In the meantime, we will be able to roll a little :aiwebs_011::aiwebs_011::aiwebs_011::aiwebs_011:
