Wolfgang Report post Posted July 20, 2007 Sorry to hear it's a major. How many KMs does your car have ? Type oil, changed often ? Am I understanding the main bearings are worn ? 34.000km / 21.250miles Oil changed every year No, not the main bearing - at he end of the crankshaft (looking direction gear box) are 4 bearings for ballance which are worn. Quote Share this post Link to post Share on other sites More sharing options...
13MM Report post Posted July 20, 2007 Sorry to be a pain Is it the thrust or endplay bearings ? # 17 & 18 in link Wondering Quote Share this post Link to post Share on other sites More sharing options...
Wolfgang Report post Posted July 20, 2007 Sorry to be a pain Is it the thrust or endplay bearings ? # 17 & 18 in link Wondering its somewhere between 14-16 directon to the flywheel and not listed Quote Share this post Link to post Share on other sites More sharing options...
Mike Report post Posted July 27, 2007 Thats what happens when you hold the clutch in while starting the car. It takes out the thrust bearings. Quote Share this post Link to post Share on other sites More sharing options...
SYNYSTR Report post Posted July 27, 2007 So, its a 170 hours job - engine out, complete strip down to the crankshaft, hand made new bearing(s), So let me get this straight. If he works on it 8 hours a day, 5 days a week, it will take him over 4 weeks to complete the job? I think you need a second opinion. Quote Share this post Link to post Share on other sites More sharing options...
IsleroMan Report post Posted July 28, 2007 Thats what happens when you hold the clutch in while starting the car. It takes out the thrust bearings. I'm not understanding how this affects the thrust bearings. What's the failure mechanism? Why would this only be an issue at startup and not everytime you shift? Quote Share this post Link to post Share on other sites More sharing options...
Wolfgang Report post Posted July 28, 2007 Hello gents, update: what and why exactly the damage happend. 1 of the bearing shell (bushing) turned inside the bed. So, the plughole for the oil and lubrication was hidden/closed. No more lubrication for the crank shaft on this point. The bearing went hot and destroyed. The crank shaft is now tarnished and needs a complete revision - lots of time / money in another special firm. The crank case is also heavy damaged and needs a revision. New bearings.....a.s.o. Hope the pics will help to understand what I try to translate? Quote Share this post Link to post Share on other sites More sharing options...
Wolfgang Report post Posted July 28, 2007 Biggest problem is time. My garage master is (as usual) totally overloaded with work. Just to give you a glimpse of a "normal" day... - testarossa - my diablo vt - 360 CS - Bugatti EB110 - diablo GT 46/80 outside and waiting: - 2 x countach - 355 - 360 - mondial and 20 more Ferraris/Lamborghinis stored in an extra garage waiting for maintenance. Some of the work (edging, honing) must be done in an extra & specialized firm. Quote Share this post Link to post Share on other sites More sharing options...
topcabron Report post Posted July 28, 2007 I hope this is not a common problem that a lot of us can look forward to. Good luck, and I hope your mechanic can work you in. Quote Share this post Link to post Share on other sites More sharing options...
Wolfgang Report post Posted July 28, 2007 I hope this is not a common problem that a lot of us can look forward to. Good luck, and I hope your mechanic can work you in. Common problem......so far the "hint" came from the factory in Italy!!! After replacing and fixing almost everything, we called the Lamborghin ifactory, spoke to a technical and he told us about the crank shaft, bearings, play, turning of the bearing shell and this is the reason that the time & speed sensor (the one at the flywheel) works wrong. And the damage of the crank shaft and crank box........not realy unkown! So, the problem is known at the factory and not the first time or one of a kind. Quote Share this post Link to post Share on other sites More sharing options...
13MM Report post Posted July 30, 2007 Wolfgang, Thank you for the pictures. Sorry to see the damage. Just for your information, in the USA we identify this as a ( past tence of spin) spun main bearing . Good luck, hope yor auto is repaired soon and this becomes a past memorie. Quote Share this post Link to post Share on other sites More sharing options...
Wolfgang Report post Posted July 30, 2007 Wolfgang, Thank you for the pictures. Sorry to see the damage. Just for your information, in the USA we identify this as a ( past tence of spin) spun main bearing . Good luck, hope yor auto is repaired soon and this becomes a past memorie. Thank you very much for the translation/identification in English/US. Its a real challenge for me to translate tech. stuff, which I even don`t know in german, in another language. Thanks for your help. And thanks a lot for you kind words. YES, time will come and it will be a past memorie....with a huge hole in my wallet. Quote Share this post Link to post Share on other sites More sharing options...
