A23 Report post Posted November 3, 2009 Hey guys, any tips on removing the center console? I've looked and there is no visible screws or whatsoever. I don't want to break stuff by just pulling it out without knowing anything. Any input is appreciated. Thanks Anthony Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted November 3, 2009 Hey guys, any tips on removing the center console? I've looked and there is no visible screws or whatsoever. I don't want to break stuff by just pulling it out without knowing anything. Any input is appreciated. Thanks Anthony What part of the center console hare you removing ? The upper part around the radio with A/C controls ? If so then you need to remove the radio. You must remove the center console side cover by the fuse box cover in the right side foot well. There is a back strap for the radio. Then I use a 1.5mm allian to go into the holes in the front of the radio to relese its side clips then the radio slides out. You must then remove the radio din box (small metal fram that the radio clips into) it has tabs that are folded out to hold it. You fold the tabs back in kinda of a pain. Then there are two 3mm? allians that holds the pice that fits around the radio. If you are looking into the empty radio hole they are on the sides, remove them and you can carefully lift the pice out. You must unplug the A/C contol pad and it is off. You must be very carefull when removing the radio and the din box for if you bump the edges of the center pice it can peel the black soft touch paint very easy. If it is the lower part say where the window switches are thats alot more work and you can damage the leather very easy. Quote Share this post Link to post Share on other sites More sharing options...
Scotty Report post Posted November 3, 2009 What part of the center console hare you removing ? The upper part around the radio with A/C controls ? If so then you need to remove the radio. You must remove the center console side cover by the fuse box cover in the right side foot well. There is a back strap for the radio. Then I use a 1.5mm allian to go into the holes in the front of the radio to relese its side clips then the radio slides out. You must then remove the radio din box (small metal fram that the radio clips into) it has tabs that are folded out to hold it. You fold the tabs back in kinda of a pain. Then there are two 3mm? allians that holds the pice that fits around the radio. If you are looking into the empty radio hole they are on the sides, remove them and you can carefully lift the pice out. You must unplug the A/C contol pad and it is off. You must be very carefull when removing the radio and the din box for if you bump the edges of the center pice it can peel the black soft touch paint very easy. If it is the lower part say where the window switches are thats alot more work and you can damage the leather very easy. Here is a diagram, I just upgraded mine to all carbon. Scott Murci_Center_Console_Installation_Instructions.pdf Quote Share this post Link to post Share on other sites More sharing options...
GregR-Tuned Report post Posted November 4, 2009 would anyone be interested in a carbon fiber radio/a/c console? Quote Share this post Link to post Share on other sites More sharing options...
A23 Report post Posted November 4, 2009 Thanks alot guys! You guys rock! Quote Share this post Link to post Share on other sites More sharing options...
Phantastik Report post Posted November 20, 2009 id take the that radio off your hands if you need room in the garage. Quote Share this post Link to post Share on other sites More sharing options...
A23 Report post Posted November 20, 2009 id take the that radio off your hands if you need room in the garage. Hey sure, I don't need it anymore. how much? Quote Share this post Link to post Share on other sites More sharing options...
Phantastik Report post Posted November 21, 2009 Hey sure, I don't need it anymore. how much? i dont have much cash. Im a college student i just want to own something lamborghini makes as a motivational tool. Quote Share this post Link to post Share on other sites More sharing options...
