DoctaM3 Report post Posted August 9, 2010 Nothing too exciting but finally decided to swap out 21% oxygen for pure nitrogen Anyway, I was bored while the operation was going on, so I figured I would document it--here goes (watch in HD) I know others on here have done this. I assume as long as the tire holds the pressure, you never have to do much but is there ever a need for another infusion? If so, how often? What if you need to add air, i assume its would be contaminated and you will have to re-do the process, correct? I am sure others who have been considering it have the same questions. Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted August 9, 2010 For the most part...Nitrogen 'infusion' for street cars is a complete scam. Quote Share this post Link to post Share on other sites More sharing options...
LAUTLOS Report post Posted August 9, 2010 > For the most part...Nitrogen 'infusion' for street cars is a complete scam. The German Wikipedia article does an excellent job of dispelling the myths. http://de.wikipedia.org/wiki/Reifengas#Arg...gegen_Reifengas http://translate.google.com/translate?u=ht...sl=de&tl=en Quote Share this post Link to post Share on other sites More sharing options...
Rouleur Report post Posted August 9, 2010 While I hear what you are screamin', I have had nitrogen in my tires for a while on most of my cars (I get it pretty much for free when I get tires) and I never have to add air. They just don't lose pressure. May just be me, but I have been happy with it. I suppose there is some science to it and a lot of fallacy due to the added revenue. Thanks for posting those links, interesting reading. Quote Share this post Link to post Share on other sites More sharing options...
Smoky Report post Posted August 9, 2010 While I hear what you are screamin', I have had nitrogen in my tires for a while on most of my cars (I get it pretty much for free when I get tires) and I never have to add air. They just don't lose pressure. May just be me, but I have been happy with it. I suppose there is some science to it and a lot of fallacy due to the added revenue. Thanks for posting those links, interesting reading. I have to admit I didn't even think people were considering this a myth. Especially with so much evidence of the effectiveness. The main idea, I thought, was not specifically that you were using nitrogen but that the end result is moisture-free air inside your tire (I haven't read the links posted above so I assume they refute this?). Without moisture the deviation of pressure does occur "as much". Quote Share this post Link to post Share on other sites More sharing options...
Zmydust Report post Posted August 17, 2010 While I hear what you are screamin', I have had nitrogen in my tires for a while on most of my cars (I get it pretty much for free when I get tires) and I never have to add air. They just don't lose pressure. May just be me, but I have been happy with it. I suppose there is some science to it and a lot of fallacy due to the added revenue. Thanks for posting those links, interesting reading. I have regular air in mine and never have to add air either. Quote Share this post Link to post Share on other sites More sharing options...
LAUTLOS Report post Posted August 17, 2010 > The main idea, I thought, was not specifically that you were using nitrogen but that the end result is moisture-free air inside your tire. The starting point is a freshly mounted tire, with air in it... and moisture. If you want to avoid that, then you'd need to either evacuate that air (which is hard -- the tire isn't that flexible) or do the mounting in a climate chamber (set to bone dry -- I have yet to see someone doing that). From said starting point you pump in either air or nitrogen. Which does involve a compressor. Which should have properly functioning filters for water, oil, etc., no matter which gas it is actually compressing. The end result? The same amount of moisture in your tires. Quote Share this post Link to post Share on other sites More sharing options...
