jhbchess Report post Posted March 16, 2013 Driver side: the space between tire and fender is 1/2 inch lower than that of the passenger side. The distance from ground to bottom of bumper/splitter is same on both sides. Both struts are dry, but the driver side could have leaked in the past I suppose. I'm assuming the lift system can't "go too low" on one side, but maybe it's not releasing far enough on the passenger side? Quote Share this post Link to post Share on other sites More sharing options...
Kisco Report post Posted March 16, 2013 Take it to the dealer, Joe. That is the beauty of having a warranty..=) Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted March 16, 2013 Talk to the contractor who did your garage floor Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted March 17, 2013 Nothing to do with the strut system if it's down. It will either work or not work and you will have power steering problems if your low on fluid. Just the way the car may be sitting. Remember you always sit in the drivers side when you drive. If you have coilovers then take it to get corner balanced with you in the car. Sometimes that helps a lot. More important to be corner balanced then to look symmetrical. Quote Share this post Link to post Share on other sites More sharing options...
jhbchess Report post Posted March 17, 2013 Talk to the contractor who did your garage floor Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted March 17, 2013 Quote Share this post Link to post Share on other sites More sharing options...
