Guest Thatmansebastian
E gear light on
Have a 06 battery was disconnected for awhile . Once battery got connected again I have a e gear light on that won’t go away and I can’t go to 3rd-6th without going to neautral each time then upshiffting
I’ve checked fluid
new battery
clutch was replaced last year
held in paddles but goes to auto mode and it won’t Shift to third
Same battery specs as OEM? Hooked up properly? Just wondering if it's out of spec or got hooked up backward you toasted something.  Have you checked all your fuses?
I have not checked but yes agm 34 I replaced battery just the other day when I read people were saying on google can be a voltage issue . The pump kicks on when door is opened
