oneofew Report post Posted August 25, 2020 Latley OEM Alpine unit in my 97 Roadster's turning on by itself. Car can be parked for couple of months and its quiet, randomly one day it turns on at max volume. This also brings up the question, from day one my headunit worked independently from the ignition, as in most normal cars when you turn off the ignition head unit shuts off . On my car I have to turn it off manually. Any of you had any similar experience or encounered a problem such as this? Quote Share this post Link to post Share on other sites More sharing options...
Destructo Report post Posted August 26, 2020 Sounds like a short. Was the unit installed later than originally purchased? Wondering if any work near it lately, or on install is causing the grief. Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted August 27, 2020 Mine does not turn off with the ignition. Quote Share this post Link to post Share on other sites More sharing options...
oneofew Report post Posted September 1, 2020 @ Destructo, Thank You. This unit has been in the car from day one, OEM connections never spliced for an aftermarket system, my gut feeling is it may very well have a internal short , once I detach the face plate it doesn't come back on. Another possibility is the remote control or the remote function picking up interference from some other source. @ Allan-Herbie, thank you for clarifying . Quote Share this post Link to post Share on other sites More sharing options...
