Mingjirayu Report post Posted May 13, 2021 Hi my Diablo 94 VT has been overfueling on 1 bank. I have try swapping ecu, new 02 sensor, and change all injectors (aftermarket accel), but still overfueling on the same bank. Pressure on the 2 fuel pump are the same. Can you please help recommend me on the solution? Quote Share this post Link to post Share on other sites More sharing options...
jtse30 Report post Posted May 14, 2021 Just a guess, you have air entering the system from somewhere, did test for leaks? Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted May 14, 2021 Have you checked the vacuum line going to the map sensor? If good swap map sensors. Quote Share this post Link to post Share on other sites More sharing options...
Destructo Report post Posted May 14, 2021 What size are the new injectors? Quote Share this post Link to post Share on other sites More sharing options...
