Brock Report post Posted July 14, 2021 How are you guys?! Can somebody please tell me what the Correct/Best Power Steering/Lifting System oil is for my 2004 Murcielago. The service manual I have lists the correct oil as AGIP DEXRON II; however, I don't believe that this oil is manufactured any more. Hopefully, this is something that I can buy at AutoZone, Advance Auto Parts, etc. Also, what areas should I check for Power Steering/Lifting System oil leaks. I think that the Murcielago is currently harder to steer, and the Front Lifting System only works partially/intermittently, and shows an error message on the dashboard when I activate it. I know that Power Steering/Lifting System oil leaks are a common problem for first generation Murcielagos. I searched for answers to these questions on this forum, but wasn't able to find the answers that I need. As always, I greatly appreciate any help from the great and knowledgeable people on this forum. Best Regards--Brock Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted July 25, 2021 Dexron IV or V can be used in systems that call for Dexron II. Make sure when you add fluid to have lift system down or you will over fill it (better a little low then over filled) and it will make a mess when you drive it and it gets hot. They can leak from any part of the lift or P/S system. Must inspect. The shocks can leak, steering rack, hoses to steering rack, lift supply hose, high pressure hose from pump to lifting system are the more normal items. Quote Share this post Link to post Share on other sites More sharing options...
