whiteout Report post Posted May 17, 2012 My car has a misfire that occurs randomly, with no code coming up. I think from the left bank. The car is definitely down on power and feels sluggish. I wondered if anybody had an idea of what might be causing this? Ideas: Bad Spark Plug Clogged Air Filter Weak Battery Clogged Cat Vacuum Leak Nick Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted May 18, 2012 I would start with checking the spark plug unions for water. Pull coils look for water and or rust. Swap coils from one side to the other see if the other side has misfire. Quote Share this post Link to post Share on other sites More sharing options...
Kipper Report post Posted May 19, 2012 My car has a misfire that occurs randomly, with no code coming up. I think from the left bank. The car is definitely down on power and feels sluggish. I wondered if anybody had an idea of what might be causing this? Ideas: Bad Spark Plug Clogged Air Filter Weak Battery Clogged Cat Vacuum Leak Nick Hi Nick My Murci was hunting with the occasional pop just like yours after a reply/advice from Jefflambo I did just as he has suggested for you to do Check coil packs for water. I cleared the water and replaced the plugs and all was well. ( Jefflambo did tell me to consider replacing coil packs at the time also Approximately 12 months later I replaced the coil packs and wow my Murci ran so much better very smooth and crisp on the throttle In my opinion Clean, New plugs & Coils. dont stuff around you wont regret it, Let us know how you go Kipper Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted May 20, 2012 Thanks! Nick Quote Share this post Link to post Share on other sites More sharing options...
jags911tt Report post Posted August 13, 2012 Im having the same problem. But I have only driven in rain twice over the last 6 months and car has 14k on it. Could it just be plugs? If so are they easy to replace or something for a dealer? Quote Share this post Link to post Share on other sites More sharing options...
jags911tt Report post Posted August 13, 2012 How do you clean the coil packs? Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted September 7, 2012 my murcie is behaving exacly the same as yours in the video, and also when i push the car hard on the highway im getting check engine lamp and catalyst L on the dash, today i got beaten by a BMW M5 -05 it was going great on second gear where he was behind me and on third gear i get the engine lamp on and se how he slowly run past me, i feel the car has lost it power. And btw i been driving the car rainy days and it has also been kept outside when its been raining. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted September 8, 2012 I ended up having water in the spark plug holes. I replaced with new plugs; NGK DCPR9EIX 2316. It's an easy job, I put a write up here: http://lambodiy.blogspot.com/p/how-to-repl...k-plugs-in.html How do you clean the coil packs? I also have that in the link above. Nick Quote Share this post Link to post Share on other sites More sharing options...
azmurciev12 Report post Posted September 8, 2012 Denso IXU27 might be the better spark plug to use. to avoid water getting into the coilpacks, put a plastic cover over the engine before washing the car so the water doesn't drip straight to the engine. eversince i did that, i never had problems with water entering the coilpacks. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted September 8, 2012 Yeah, that's a great way to prevent water getting in during washes. I make a tent out of towels and it does a good job. I have issues of water getting into the plug holes during heavy rain. Nick Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted September 9, 2012 Could someone post the oem nr for the coil packs? Thanks. Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted September 10, 2012 Im getting this sparks from my dealer DCPR9EVX 6436 do you know if those works bescuase he cant find the ones you are using. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted September 10, 2012 I am not sure, that's a different plug. I bought my last two sets from Advanced Auto Parts and Amazon.com. The guy at Advanced said to search using the last 4 digits as that's how most auto parts stores categorize NGK plugs. Nick Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted September 12, 2012 I am not sure, that's a different plug. I bought my last two sets from Advanced Auto Parts and Amazon.com. The guy at Advanced said to search using the last 4 digits as that's how most auto parts stores categorize NGK plugs. Nick I have odered champion spark plugs from eurospares as i couldnt get the ones you are using. So i will try clean my coil packs and replace the sparks and hope that will help. Quote Share this post Link to post Share on other sites More sharing options...
Shunolago Report post Posted September 12, 2012 Strange i just got the package and they send me denso ixu27 plugs guess they will work fine Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted September 12, 2012 That's an iridium plug, so you should be in good shape. Nick Quote Share this post Link to post Share on other sites More sharing options...
