gLA Report post Posted September 23, 2009 I can't put my finger on it but the front feels like it gets light at high speeds and the steering feels looser as well at these speeds. It's not a huge difference but I'm sure it's there. I'm trying to work out if I should take it to Lamborghini but since I have had the car lowered would it be better off at a place that just works on suspension set ups etc? Any experienced advice is appreciated cheers g Quote Share this post Link to post Share on other sites More sharing options...
capt_chaos Report post Posted September 23, 2009 Silly question, have you checked tyre pressure? Next is Geo. Quote Share this post Link to post Share on other sites More sharing options...
keyz2dabenz Report post Posted September 23, 2009 GMG Racing (714) 432 -1582 SP Engineering (626) 333-5398 Quote Share this post Link to post Share on other sites More sharing options...
gLA Report post Posted September 23, 2009 Yes, tyre pressure is correct. What's Geo? Silly question, have you checked tyre pressure? Next is Geo. Quote Share this post Link to post Share on other sites More sharing options...
rghataode Report post Posted September 23, 2009 Geometry/Alignment. Quote Share this post Link to post Share on other sites More sharing options...
dragvorl Report post Posted September 24, 2009 Suspension geometry, I suppose. Quote Share this post Link to post Share on other sites More sharing options...
FormulaGT Report post Posted September 24, 2009 SP Power / Lucent / AutoTalent / GMG Quote Share this post Link to post Share on other sites More sharing options...
dgsk Report post Posted September 24, 2009 Definitely sounds like the suspension needs to be tightened. They do come loose after a while on G's but not as quickly as the M's. It happened to me when I 1st got my car. Above 230km/h on the speedo, the car suddenly floated. Luckily, there was a mechanic nearby and quickly resolved the issue. Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted September 24, 2009 G, Take it to Johnson Alignment in Torrance. They did my car recently and did a beautiful job. Prices are reasonable. I had my car corner balanced with me in the car and an alignment. Plus they replaced my front bushings that were worn out. Quote Share this post Link to post Share on other sites More sharing options...
gLA Report post Posted September 24, 2009 That sounds good, I'll give them a shout. However I had the wheels aligned not so long ago so I don't know if it's that. Would worn bushings make it feel floaty at speed? Hope your well and your wee boy is healthy and happy g G, Take it to Johnson Alignment in Torrance. They did my car recently and did a beautiful job. Prices are reasonable. I had my car corner balanced with me in the car and an alignment. Plus they replaced my front bushings that were worn out. Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted September 24, 2009 That sounds good, I'll give them a shout. However I had the wheels aligned not so long ago so I don't know if it's that. Would worn bushings make it feel floaty at speed? Hope your well and your wee boy is healthy and happy g Worn bushings could definitely lead to floaty handling at speed. I bought a set from BH Lambo for around $60 and had them install them. Transformed the car. Turn in was much more precise, reduced understeer. They will look at the toe and camber. Which could be a problem too. They do a lot of suspension tuning for race cars, they really know what they are doing. We are well, Noah is doing great, almost walking. Quote Share this post Link to post Share on other sites More sharing options...
gLA Report post Posted September 24, 2009 Cheers for that! Worn bushings could definitely lead to floaty handling at speed. I bought a set from BH Lambo for around $60 and had them install them. Transformed the car. Turn in was much more precise, reduced understeer. They will look at the toe and camber. Which could be a problem too. They do a lot of suspension tuning for race cars, they really know what they are doing. We are well, Noah is doing great, almost walking. Quote Share this post Link to post Share on other sites More sharing options...
Toreador Report post Posted September 24, 2009 +1 to the Johnston suggestion. Took my G there after Kinnsella did his and they did a bang-up job. I have to take my Porsche there too whenever I get some time. Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted September 25, 2009 G.... Have them realign your car. I'll pay for it if you aren't happy, you will notice the difference. They sanded the hubs of 2 of my wheels to remove overspray rather than add wheel weights when doing the corner balance. Quote Share this post Link to post Share on other sites More sharing options...
gLA Report post Posted September 25, 2009 Good idea, I'm going to book in for next week. The only problem is finding enough time to get out there. Did they do it while you waited? If I'm feeling confident enough after it's done then we can go play on the twisty stuff? G.... Have them realign your car. I'll pay for it if you aren't happy, you will notice the difference. They sanded the hubs of 2 of my wheels to remove overspray rather than add wheel weights when doing the corner balance. Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted September 25, 2009 yeah it took less than an hour to change the bushings. Quote Share this post Link to post Share on other sites More sharing options...
DrJ Report post Posted September 25, 2009 Worn bushings could definitely lead to floaty handling at speed. I bought a set from BH Lambo for around $60 and had them install them. Transformed the car. Turn in was much more precise, reduced understeer. They will look at the toe and camber. Which could be a problem too. They do a lot of suspension tuning for race cars, they really know what they are doing. We are well, Noah is doing great, almost walking. How many miles on the G do the bushings have to be replaced? Any estimates? Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted September 26, 2009 How many miles on the G do the bushings have to be replaced? Any estimates? I drive my car pretty hard. Just after 15k miles one of the bushings disintregrated. When I replaced both, the remaining one was really worn too. Quote Share this post Link to post Share on other sites More sharing options...
Carnut1 Report post Posted September 27, 2009 After my car was converted to RWD, I had to have the suspension rebalanced. I have a 04 and there was a campain on the bushings (the previous owner never brought it in to be done), and they were in terrible condition. They also found that that things needed to be tighten up. Quote Share this post Link to post Share on other sites More sharing options...
wildkalabaw Report post Posted October 9, 2009 yeah it took less than an hour to change the bushings. Kinnsella, Do they have Lambo fit bushings, or do I have to buy from BH and bring it in? I don't feel anything wrong with my G. I'm just taking your suggestion, and I want to make sure that everything is right and tight. TIA Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted October 9, 2009 Kinnsella, Do they have Lambo fit bushings, or do I have to buy from BH and bring it in? I don't feel anything wrong with my G. I'm just taking your suggestion, and I want to make sure that everything is right and tight. TIA I ordered the bushings from BH Lambo. They do not have them, took about a week, they were $60 or so for the pair. gla took his car in to Johnson's Alignment, his car did not need bushings, but they did do alignment and corner balance (i believe). He told me the floatiness had gone away and that the car was much more predictable. Quote Share this post Link to post Share on other sites More sharing options...
gLA Report post Posted October 12, 2009 yeah they did a great job, I just got back from Palm Springs and the car felt rock solid. It used to get really light under load at the front, now it's planted and true. I wouldn't hesitate to recommend them. Hey Kinnsella, I like your new sig! I ordered the bushings from BH Lambo. They do not have them, took about a week, they were $60 or so for the pair. gla took his car in to Johnson's Alignment, his car did not need bushings, but they did do alignment and corner balance (i believe). He told me the floatiness had gone away and that the car was much more predictable. Quote Share this post Link to post Share on other sites More sharing options...
