ijvpet Report post Posted March 10, 2010 It seems to be working fine. All the functions work. Obviously it signifies some sort of problem. It has been in storage for a few years however. Is there a way I can reset it? Quote Share this post Link to post Share on other sites More sharing options...
4xchamp Report post Posted March 10, 2010 I've seen some civilian cars flash the same warning . It indicates the refrigerant charge is low . I don't know if this applies to your Murc , but checking it is fairly easy . Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted March 11, 2010 I have seen this in cars that have had dead battery's for a long time. There is a reset for the unit. I will need to check some of my books as it has been a while since I have done it. More less you will hold 2 buttons down and turn the key on but I will have to look it up which 2 buttons I will post it tomorrow. Quote Share this post Link to post Share on other sites More sharing options...
EURO_C Report post Posted March 11, 2010 This means that the control panel has detected a fault in some sensors or blend door actuators. This "Service Message" happens only when there is a problem detected it will rarely happens by a dead battery and if it does it is a glitch. I'll P.M. you the procedure info. Quote Share this post Link to post Share on other sites More sharing options...
jefflambo Report post Posted March 11, 2010 This means that the control panel has detected a fault in some sensors or blend door actuators. This "Service Message" happens only when there is a problem detected it will rarely happens by a dead battery and if it does it is a glitch. I'll P.M. you the procedure info. Wrong!! If it has a fault in the sensors or the flaps it will give a code for the fault or it will say error. When it says service it thinks its a new unit installed. If the cars set for long enough with no power the system can loose its setting and thinks it is a new unit and wants to run a self learn or whats called a reset I have seen this more then once. Press and hold down the auto button turn the key to the on postion the letter I will appear along with the basic control symbol followed by the letter B during the self learn. At the end the unit will switch to auto mode and the temp will set at 23 deg. C. then press and hold the text button 2nd button to the right next to the auto button this will change the temp display back to F. Let us know after you run the reset how it works out I will bet the service will go away. I just ran the reset on a car the temp display read 73 deg F when done if it reads in C then do the last part with the text button if it is F then your done. Quote Share this post Link to post Share on other sites More sharing options...
EURO_C Report post Posted March 11, 2010 Wrong!! If it has a fault in the sensors or the flaps it will give a code for the fault or it will say error. When it says service it thinks its a new unit installed. If the cars set for long enough with no power the system can loose its setting and thinks it is a new unit and wants to run a self learn or whats called a reset I have seen this more then once. Press and hold down the auto button turn the key to the on postion the letter I will appear along with the basic control symbol followed by the letter B during the self learn. At the end the unit will switch to auto mode and the temp will set at 23 deg. C. then press and hold the text button 2nd button to the right next to the auto button this will change the temp display back to F. Let us know after you run the reset how it works out I will bet the service will go away. I just ran the reset on a car the temp display read 73 deg F when done if it reads in C then do the last part with the text button if it is F then your done. That is true, but don't bash me yet we are in the same field. My post is from what I have personally seen and repaired. I sent ijvpet a P.M. so I can send the full PDF section of HVAC for the Murci for a better explanation. From my past experience I had a unit that went bad and read service and no error. I tried to do the "First Running - Reset" strategy found on page 21 in the HVAC section and it failed. That's when I proceeded to do the Self Diagnostic found on the following page of the manual and found no errors but the unit will not accept the Reset I had to replace it and it turned out that the vehicle previously before I worked on it had a dead battery and was jumped with a high voltage which had damaged the cluster and the PMC. I had another one with similar case except after the Self Diagnostic I found the heater solenoid valve was at fault. Jefflambo - P.M. me, thanks. Quote Share this post Link to post Share on other sites More sharing options...
ijvpet Report post Posted March 17, 2010 Thanks gents the reset worked!!! No more flashing "service" and it works perfectly. I love this forum. You guys are awesome! Thanks for your help John Quote Share this post Link to post Share on other sites More sharing options...
Nikk777 Report post Posted November 15, 2020 Thank you! The reset fixed the blinking service and now the heat works again! Quote Share this post Link to post Share on other sites More sharing options...
x98boardwell Report post Posted May 17 On 3/11/2010 at 1:50 PM, jefflambo said: Wrong!! If it has a fault in the sensors or the flaps it will give a code for the fault or it will say error. When it says service it thinks its a new unit installed. If the cars set for long enough with no power the system can loose its setting and thinks it is a new unit and wants to run a self learn or whats called a reset I have seen this more then once. Press and hold down the auto button turn the key to the on postion the letter I will appear along with the basic control symbol followed by the letter B during the self learn. At the end the unit will switch to auto mode and the temp will set at 23 deg. C. then press and hold the text button 2nd button to the right next to the auto button this will change the temp display back to F. Let us know after you run the reset how it works out I will bet the service will go away. I just ran the reset on a car the temp display read 73 deg F when done if it reads in C then do the last part with the text button if it is F then your done. @jefflambo this was super helpful. My Murcielago has sat for over 2 years (barely started) as it was in Salt Lake City getting a custom touch. When I received it back yesterday and attempted to turn on the AC I was frustrated that something had happened. Your process above took 30 seconds and everything is working flawlessly now. Appreciate your input and always love these forums for times like this!!! Cheers, Bryan Quote Share this post Link to post Share on other sites More sharing options...
