colorinc Report post Posted May 13, 2010 just finished up and xm radio install on the g... went good mounted the antenna near rear window see pic ... the reception is great traveling in all directions:) for power tapped into fuse 11 windshield washers and for the ground kick panel bolt brand= XM Onyx XDNX1V1 XM cost = $63 from walmart lol time = 2.5 hours fun = 2 thumbs up ck out the pics tim Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted May 13, 2010 Looks clean, but how do you reach it from driver side? Quote Share this post Link to post Share on other sites More sharing options...
colorinc Report post Posted May 13, 2010 great question i typically listen to just one channel .... 80's lol Looks clean, but how do you reach it from driver side? Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted May 13, 2010 Does it have an FM Modulator, or did you hard wire it to the head unit? Looks good....XM all the way! Quote Share this post Link to post Share on other sites More sharing options...
colorinc Report post Posted May 13, 2010 thanks mike! fm modulator.. seems to work great did you hard wire yours? now if i can only find a way to hook cruise up to it lol next project hardwire the v1 tim Does it have an FM Modulator, or did you hard wire it to the head unit? Looks good....XM all the way! Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted May 13, 2010 No...Mine has the FM Modulator as well...It's good enough sound for me...I'm no audiophile...Makes the install that much easier, too.. Quote Share this post Link to post Share on other sites More sharing options...
colorinc Report post Posted May 13, 2010 same here No...Mine has the FM Modulator as well...It's good enough sound for me...I'm no audiophile...Makes the install that much easier, too.. Quote Share this post Link to post Share on other sites More sharing options...
djantlive Report post Posted May 13, 2010 nice install. so you have to open the glove box to access it? seems a bit weird. i would have installed it in the left driver side glove box if it fit in there. my car is too loud to listen to music. Quote Share this post Link to post Share on other sites More sharing options...
kmr Report post Posted May 13, 2010 Damn so even newer G's dont have SAT Radio? (ie Turbo50Mike's LP560?) Thats fcuking weak!!! Isnt the radio essentially the same from Audi? My 04 S4 had SAT! Install looks like it will get the job done though colorinc. Your music choice on the otherhand.... Aside from an FM modulator, whats the other option? New head unit? Or wonder if there are AUX plugs on back on stock unit? Quote Share this post Link to post Share on other sites More sharing options...
New User Report post Posted May 14, 2010 Damn so even newer G's dont have SAT Radio? (ie Turbo50Mike's LP560?) Thats fcuking weak!!! Isnt the radio essentially the same from Audi? My 04 S4 had SAT! Install looks like it will get the job done though colorinc. Your music choice on the otherhand.... Aside from an FM modulator, whats the other option? New head unit? Or wonder if there are AUX plugs on back on stock unit? ALL 2010 Lamborghinis whether 12 or 10 cylinders have lifetime satellite radio. You can purchase the interface from Lamborghini's spare parts department and have it installed using the factory head unit. Quote Share this post Link to post Share on other sites More sharing options...
kmr Report post Posted June 22, 2010 You guys still happy with your SAT installs? Isnt the FM modulator a bit fuzzy at times....? Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted June 22, 2010 You guys still happy with your SAT installs? Isnt the FM modulator a bit fuzzy at times....? Never...On rare occasions I lose reception on the satellite end if I'm on the side of a mountain, or in heavily tree covered roads, but it's only out for a few seconds. If I had the antenna on top of the car it probably wouldn't go out at all. But it's never 'fuzzy' reception wise between the sat receiver and the head unit. You can select any station, so if interference is a problem, then just choose a station with no other available broadcast on. Quote Share this post Link to post Share on other sites More sharing options...
kmr Report post Posted June 22, 2010 Thanks for the update and reply! Just worried about the quality with merely a FM modulator but sounds like it does the trick as opposed to option B of hardwiring or replacing the stock unit. Thanks againg for the info Mike. Quote Share this post Link to post Share on other sites More sharing options...
Itzkirb Report post Posted June 29, 2010 Nice install. I'd love to have XM in the car if there was a way to hardwire it. FM mod doesn't work well in my area. V1 hardwire takes about 10mins to do. Quote Share this post Link to post Share on other sites More sharing options...
