kinnsella Report post Posted February 12, 2016 I changed my battery recently with my son and it apparently reset the computer. This year I need to smog my car. The car passes 7 out of 8 tests, the cat sensor is the only one that has not cleared. The O2 sensor is fine. The smog place says, I need to drive it a couple of hundred miles before the CAT sensor clears. Is this correct? Is there a short cut? TIA Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted February 12, 2016 Text sent. Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted February 12, 2016 Normally it's about 50 miles after a computer reset. Quote Share this post Link to post Share on other sites More sharing options...
kinnsella Report post Posted February 12, 2016 Normally it's about 50 miles after a computer reset. First world problems...will have to take it out tomorrow, going to drive Pine Mountain. Quote Share this post Link to post Share on other sites More sharing options...
djantlive Report post Posted February 12, 2016 There is a smog ready status on obd2. I would get a little scanner to check that before smogging again. Changing battery shouldn't erase the status unless you left the battery disconnected for a long long time Quote Share this post Link to post Share on other sites More sharing options...
