Ag02M5 Report post Posted November 26, 2016 Looking for a copy of the Swift spring install PDF. Thx. Quote Share this post Link to post Share on other sites More sharing options...
Devine STS Report post Posted November 30, 2016 Looking for a copy of the Swift spring install PDF. Thx. I've got a copy if your still in need Quote Share this post Link to post Share on other sites More sharing options...
Joeet Report post Posted January 15, 2017 I've got a copy if your still in need Do you still have a PDF copy of the install? If so could you please email them to [email protected]. Having some issues with the front. Thanks Quote Share this post Link to post Share on other sites More sharing options...
Devine STS Report post Posted January 23, 2017 Do you still have a PDF copy of the install? If so could you please email them to [email protected]. Having some issues with the front. Thanks Yes sir! Will do Quote Share this post Link to post Share on other sites More sharing options...
Johni Patino Report post Posted August 26, 2017 Awesome cars Quote Share this post Link to post Share on other sites More sharing options...
git54ty Report post Posted January 31, 2018 What does this video have to do with anything here? Quote Share this post Link to post Share on other sites More sharing options...
V12noise Report post Posted October 6, 2018 Hi All, does anybody have instruction manual in pdf or link for installing springs on an LP Gallardo? Quote Share this post Link to post Share on other sites More sharing options...
LamboCharlotte Report post Posted December 18, 2018 Just as an FYI, the factory suspension on a first gen G, LP G or Huracan can be adjusted to different ride heights. Assuming the adjustment is to your liking, there's no need to replace the springs to accomplish this. Unless you want it lower than what the factory hardware allows for. I would recommend an alignment following the spring replacement or adjustment as well. Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted December 18, 2018 1 hour ago, LamboCharlotte said: Just as an FYI, the factory suspension on a first gen G, LP G or Huracan can be adjusted to different ride heights. Assuming the adjustment is to your liking, there's no need to replace the springs to accomplish this. Unless you want it lower than what the factory hardware allows for. I would recommend an alignment following the spring replacement or adjustment as well. Without changing the springs, how much will the rate be affected when lowered? I'm looking at installing Swift springs after my wheels come in. Quote Share this post Link to post Share on other sites More sharing options...
LamboCharlotte Report post Posted December 19, 2018 First off, my apologies, I was incorrect in saying that the LP variant Gallardos were adjustable. I believe some are, but it depends on what suspension the car came with from the factory. Believe it or not, there was a comfort and sport option. To answer your question, I'm not 100% sure of how drastically the rate is affected. It would really depend on how much you adjust the ride height. With that being said, I don't know what the stock spring rate is to start with either. Stating the obvious, the ride will be a bit stiffer given you have less compression and rebound travel. The main advantage to sticking with stock springs IMO, is that if a shock failure/leakage occurs there is no impact on warranty coverage. If the car is out of warranty, that's obviously a mute point! Hopefully this helps. Quote Share this post Link to post Share on other sites More sharing options...
