Installing trunk tub after replacing battery
Wcbrunk
I use a little piece of rope slide it in the gasket opening rubber where the gasket will meet the tub and metal and as you start you pull out the rope as you go slide as the rope keeps the opening big enough to slide on on kind of like putting a windshield in good luck...
After you replace the battery, do you put the rubber seal on the car first or on the trunk tub first?
  • 5 months later...
speaking of which, i need to replace the battery in my 09 lp560. What battery did you go with?
I'm at 4.5 years in on an Optima red top 34/78 on my 06, zero issues. Can't say the same for the cd changer bracket which I really beat up trying to figure out how to remove it; haven't bought a replacement bracket yet lol.
