CCBs + Murcielago or early Gallardo = upcoming bolt replacement
LAUTLOS
If you have a Murcielago or early Gallardo with CCBs, then
expect this bolt replacement coming your way soon.
Murcielago
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs...3V470-8558P.pdf
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs...13V470-8871.pdf
Gallardo
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs...3V471-8558P.pdf
http://www-odi.nhtsa.dot.gov/acms/cs/jaxrs...13V471-7480.pdf
Mine was in for 60k service last week. So they managed to
replace the 40 bolts as part of that overall shop visit.
10 bolts? are these wheel bolts or rotor bolts? even if rotor bolts fail, the rotor is held in place with wheel bolts. i guess they are replacing all?
CCB is a two piece hat/rotor assembly, so no, the wheel bolts do not hold the rotor in place. Sounds like just the bolts which affix the carbon rotor to the metal hat.
