Flat Green Superleggera / Twin Turbo Project
gianca
  • Replies 224
If I saw that car parked in my office building, I'd go ape-shit and it would ruin my concentration for the rest of the day! Like running into a supermodel in the elevator at work!
Then I got to the office and I couldn't resist…
I remember the night Lambofan35 took delivery of his GTT and I was telling you how crazy fast and amazing the TTG's were.
Now you have one too! I deserve the credit! ;)
Here is my video from the night at PBIR
-James
-James
That's right, seeing the flames come out of his car on the Turnpike sold me on it....
As the bonnet was arching on the middle in between the two pins and vibrating at higher speeds 150 mph+ I decided to add a bracket that would support flat the middle section. I built the bracket then painted it in flat black and last added a foam gasket so that absorbs the vibration of the bonnet; to avoid the exposure of it I cut open the rear engine bay cover and slide the bracket in there.
Yes, it the same car; that’s a pretty fast 10 sec EVO although he got the jump on the second run it was really fun, it runs longer gears, E85 on 45 PSI of boost and sticky tires…
Evo is a high 140s, 150 trap in the 1/4, any idea how much power you were on?
I believe that his best ET was 10.01 @ 151 MPH; I only have one fuel map setting on my car (Pump gas) and don't really know the AW HP on it.
who really cares, its a freakin mitsu lol
you guys going to lambo track day tomorrow?
Dude, We'll be hanging out at the Ritz on Maui for a week... :)
:iamwithstupid:
The clips shot from the interior of that Evo sounded like every nut and bolt was loose in that damn thing.
Can't stop looking at your car, it is stunning.
  • 3 weeks later...
I finally got around weighting the car with all set and done, I was able to counter balance it almost to perfection, the only other upgrade I wanted to do was to replace the battery with a lighter version but decided not to until the one in there goes bad.
Full tank: 3486
Empty tank: 3336 (Assuming 150 lbs. of fuel)
