sprite Report post Posted May 28, 2010 This thing is worthless... Quote Share this post Link to post Share on other sites More sharing options...
GBGallardo Report post Posted May 28, 2010 Mine was always around 110* too Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted May 28, 2010 I know...It seems to be dead on accurate from 30 deg F to 70 deg F. After that, it's worthless. The sensors are usually located in the cowl area near the air intake for the climate control system (but not sure if that's where it is on the Gallardo). Quote Share this post Link to post Share on other sites More sharing options...
dragvorl Report post Posted May 29, 2010 On some cars it's in the mirrors. Quote Share this post Link to post Share on other sites More sharing options...
DickSimmons Report post Posted May 29, 2010 I believe the car needs to be moving to get accurate temperatures. Quote Share this post Link to post Share on other sites More sharing options...
Turbo50Mike Report post Posted May 29, 2010 I believe the car needs to be moving to get accurate temperatures. Doesn't seem to matter in the Gallardo...80 deg actual reads 95 deg even while cruising on the highway. Quote Share this post Link to post Share on other sites More sharing options...
carbuff Report post Posted May 29, 2010 All of the temperature gauges I have see in Gallardos are way off (about 4-5 degree C, = way more in F). At any temperature... Probably for "safety" reasons. Just like the speedometers.... Quote Share this post Link to post Share on other sites More sharing options...
paulfromtulsa Report post Posted May 29, 2010 Mine reads about 15 degrees F higher pisses me off Quote Share this post Link to post Share on other sites More sharing options...
LamboGator Report post Posted May 31, 2010 Glad I saw this thread. I knew my temp gauge was way off. I guess it's the Italian way of saying, 'hey, don't worry, it's close enough...we don't worry about silly temperatures'. Those wacky Italians!... Quote Share this post Link to post Share on other sites More sharing options...
Richard Wallace Report post Posted June 1, 2010 It is next to the bottom of the front bumper. And it is an accurate reflection of road temperatures, not air temperatures... Or at least that is what I tell people... :) Quote Share this post Link to post Share on other sites More sharing options...
carbuff Report post Posted June 1, 2010 It is next to the bottom of the front bumper. And it is an accurate reflection of road temperatures, not air temperatures... Or at least that is what I tell people... You may actually have a very valid point. If it is that close to the ground, it will pick up the radiant heat off the pavement. Which tends to be higher than the ambient air temp. That may have just explained it.... Quote Share this post Link to post Share on other sites More sharing options...
2004gallardo Report post Posted June 1, 2010 once the outside temp reaches 80 degrees plus mine is 25-30 degrees too hot. I figure they just mounted the temp sensor on top of the engine. Quote Share this post Link to post Share on other sites More sharing options...
Placid Report post Posted June 1, 2010 You have a racecar. Track temp is more important than air temp! Quote Share this post Link to post Share on other sites More sharing options...
2004gallardo Report post Posted June 3, 2010 You have a racecar. Track temp is more important than air temp! I have a streetcar, air temp waaay more important than "track" temp. Quote Share this post Link to post Share on other sites More sharing options...
BoLaS Report post Posted May 3, 2011 bringing this back fro the dead! lol does this sensor affect the cars ecu at all? I notice when mine is reading 110 outside even though its about 80 the 1-5 and 6-10 bank codes love to start flashing me Quote Share this post Link to post Share on other sites More sharing options...
NRG x Lambo Report post Posted May 3, 2011 how hot can the radiator get? could that affect the temperatures? Quote Share this post Link to post Share on other sites More sharing options...
Scotty Report post Posted May 3, 2011 It is next to the bottom of the front bumper. And it is an accurate reflection of road temperatures, not air temperatures... Or at least that is what I tell people... :) That is exactly what I was told....road temp for tire holding, racing. Quote Share this post Link to post Share on other sites More sharing options...
