well...What kind equipment of this in Aventador?
youlingep
that's what i'm thinking. perhaps an access panel to use the key to open door in case of no power?
The panel for that was on the left hand side when I saw the car at the factory. This car might be right hand drive?
You are right. You open it to use the key and then to open the door if there is no power. The door handle that you normally use is a elec. release so if there is no power you need a spot to unlock and open the door. It has it on both sides for right or left hand drive.
