Off-center engine location....why?
Unotaz
Can someone explain this to me? Why does every Lamborghini engine (eg. Gallardo, Gallardo LP560/570, Aventador) is positioned slight off centered? Is there a specific reason why they do that?
Other manufacturers like Ferrari or Mclaren always have their mid engine right in the middle (in comparison to the left and right side)....
It is even off center on the RWD Diablos although they may have been already planning an AWD system so they did it to minimize changes for the new setup.
And in the Gallardo Balboni ?
The Balboni/550-2/560-2 are RWD with an exact running gear as their 5XX-4 counterparts with the front diff and axles removed, positioning of the engine and gearbox should be identical across the range.
Yep, the engine in my Balboni is also slightly off center.
Yep, all of them are off center (not sure about early Diablo's/Countach).
Ever seen the leaning tower of Pisa?. Since when can Italians center anything? Itsa ok..shea close enough..but wait, wait, the gallardo is German!! Hmmm..never mind!!
Today at the track I saw a GT3 Gallardo and the engine was off centred too.
They all use the same frame and motor mounts so every Gallardo will have the same position.
