Georgev12 Report post Posted June 16, 2015 Saw Chadbourn Bolles on Lamborghinichat, posted a thread titled Super Countach. It is my understanding he cannot post here.. I found what he posted was VERY interesting to say the least. He has, or is building a BIG Countach engine that he says should make 600 or more HP. He has made or has had made just about every part for the new engine. I was able to capture some of the pics he posted and thought some here might like to see them. I did a few under the heading Chad Bolles, if you go there you can see those. These are some new ones, I was able to get. Aluminum radiator Aluminum double adjustable shocks Custom headers, larger primary pipes Connecting pipe 3 inches ID Muffler also 3 inch Valve shim, stock next to special... Stock weighs around 22 gr the special around 15 gr, that is a lot when you multiply it be 48. Titanium retainers and the actual valve adjusting shim. Kawasaki motor cycle valve springs, 30 more lb seat pressure. He said engine is being built to turn 9000 rpm. All I can say is WOW, lot of work there. Georgev12 Quote Share this post Link to post Share on other sites More sharing options...
capt_chaos Report post Posted June 19, 2015 Saw Chadbourn Bolles on Lamborghinichat, posted a thread titled Super Countach. It is my understanding he cannot post here.. I found what he posted was VERY interesting All I can say is WOW, lot of work there. Georgev12 The reason why you saw Chad's post on Lambochat was simply because you are Chad. Don't treat us like morons and we will treat you the same. You have the same IP as CHAD and Chad is not banned. Yet. Keep up this ballshit charade though and you will be. Grow up. Quote Share this post Link to post Share on other sites More sharing options...
abolfaz Report post Posted November 10, 2015 The reason why you saw Chad's post on Lambochat was simply because you are Chad. Don't treat us like morons and we will treat you the same. You have the same IP as CHAD and Chad is not banned. Yet. Keep up this ballshit charade though and you will be. Grow up. Lol. Quote Share this post Link to post Share on other sites More sharing options...
Robster Craws Report post Posted November 11, 2015 The reason why you saw Chad's post on Lambochat was simply because you are Chad. Don't treat us like morons and we will treat you the same. You have the same IP as CHAD and Chad is not banned. Yet. Keep up this ballshit charade though and you will be. Grow up. Epic Quote Share this post Link to post Share on other sites More sharing options...
IanMan Report post Posted November 11, 2015 Regardless of how funny this is, Chad, I want to see more of this car! Quote Share this post Link to post Share on other sites More sharing options...
Jpegs13 Report post Posted November 19, 2015 The reason why you saw Chad's post on Lambochat was simply because you are Chad. Don't treat us like morons and we will treat you the same. You have the same IP as CHAD and Chad is not banned. Yet. Keep up this ballshit charade though and you will be. Grow up. Quote Share this post Link to post Share on other sites More sharing options...
