My AC done today, need help?
Greenbeast
Hello all, I have a 2009 lp560 and today the AC is suddenly bad.
the tech said that is the evap.
my question is, can it be repaired?
where to get a new one?
price?
Im asking all this cuz Im not from USA and is kind a difficult to find that part in my country.
any news will be great to help, thanks!
  • 9 months later...
Edit: may 2017 was the original post!
Search ac issue, hot air, hcv. Gallardo heater control valve is known to failure. I have never heard of the evaporator failing. Detailing the exact issue would be helpful
price?
I’ve done some work with AC units outside of cars, provided the units function similarly, i’d have a few questions for your tech.
1. Did he show you damage to the evaporator coil? Or is it not that kind of problem? I’m assuming that’s what he’s saying is bad? If not, i’d recommend getting a second opinion.
2. Did you notice any drips or liquid under the car at any point (that wasn’t water)?
3. When’s the last service you had on your car? Check with your local dealer, but they should check your refrigerant level when doing a service, that could tell you something too.
Best of luck!
There is a sensor under the front hood that is known to go bad.
The trunk liner needs to be removed and it is easily accessible.
I did mine, took longer to get the liner out than it did to swap the part.
Mine suddenly only blew hot air also. Car had about 2k miles on it at the time.
