exoticalex Report post Posted August 1, 2011 I am looking at upgrading the tail lights on my 05 Murci, and I ran across a thread that mentioned 02-04's needing custom fabrication, but 05-06's didnt. Is this true? Quote Share this post Link to post Share on other sites More sharing options...
camaro97 Report post Posted August 1, 2011 I am looking at upgrading the tail lights on my 05 Murci, and I ran across a thread that mentioned 02-04's needing custom fabrication, but 05-06's didnt. Is this true? Did you find this thread: http://www.lambopower.com/forum/index.php?showtopic=32243 I am pretty sure the taillights are the same for 02-06, but maybe a mechanic or someone with a parts manual can verify. Quote Share this post Link to post Share on other sites More sharing options...
exoticalex Report post Posted August 2, 2011 Did you find this thread: http://www.lambopower.com/forum/index.php?showtopic=32243 I am pretty sure the taillights are the same for 02-06, but maybe a mechanic or someone with a parts manual can verify. That was the thread that I got the conflicting information. I couldnt imagine the 05-06 being any different, as the bodys are the same. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 2, 2011 It should be exactly the same on '02-'06. Nick Quote Share this post Link to post Share on other sites More sharing options...
vrracr Report post Posted August 12, 2011 I just did this last weekend. Here is a link to my DIY write up for the taillight conversion. I tried to be as detailed as possible so almost anyone can do it. I hope this helps someone out there. http://www.safeer.us/?p=239 Quote Share this post Link to post Share on other sites More sharing options...
Kipper Report post Posted August 12, 2011 I just did this last weekend. Here is a link to my DIY write up for the taillight conversion. I tried to be as detailed as possible so almost anyone can do it. I hope this helps someone out there. http://www.safeer.us/?p=239 Nice post Vrracr How did you make the bracket to support the outside of the light? when I dis my conversion I found that it was only possible to use one of the support bolts on the outside (the lower one) I generally found the conversion to be ok except for the poor light support on the outside The job look great when finished Kipper Quote Share this post Link to post Share on other sites More sharing options...
vrracr Report post Posted August 12, 2011 Kipper, I wrote about this in my post. When I started cutting, I was very conservative and did little by little along the top and outside edges. I kept cutting (I started with the right side first) and kept trying to fit the light in. When I got it perfect, I realized that no bracket was going to be necessary. The light fits in so snug that it wouldn't move even before putting in the screws that hold it to the car. Then I used the right side as a guide to cut the left and got it right the first time. IMO, the brackets are only necessary if you cut too much out. Otherwise, a fatter edge on the outside helps secure the lights. Mine are not going anywhere considering the force it took to get them in. Of course, the screws on the inner sides will also make sure of this. Nice post Vrracr How did you make the bracket to support the outside of the light? when I dis my conversion I found that it was only possible to use one of the support bolts on the outside (the lower one) I generally found the conversion to be ok except for the poor light support on the outside The job look great when finished Kipper Quote Share this post Link to post Share on other sites More sharing options...
Jagata Report post Posted August 12, 2011 Thanks Vrracr for the nice tutorial it will be used by many for sure. Quote Share this post Link to post Share on other sites More sharing options...
