limey Report post Posted October 27, 2009 nice set up, please post them! I'll put up pictures next week sometime when Jethot send them back. Regarding the throttle bodies: We was able to bore them out to the following: Bore 1: Stock 39mm - Modified 42mm Bore 2: Stock 54mm - Modified 57mm That's about as safe an increase as i felt comfortable with. I'll finish re-flowing them later this week and post up a report. Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted October 27, 2009 Great job limey! Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted November 2, 2009 Something for the cross ref. parts list. Was removing the oil filter housing today & snap, broke the bloody oil pressure sender in the housing. Lamborghini part # 001530303 $170.07 VDO Part # exact replacement $25.75 I'll have lots of interesting pictures uploaded Monday, esp curious about the A/C system, looks like it's an easy fit to add an additional A/C condenser to the other radiator, i will investigate this more next week. Hopefully it will work a direct bolt in which i think it will and allow much greater cooling efficiency here in the awful Florida heat & Humidity next summer. Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted November 17, 2009 Throttle body specs, before and after enlarging both ports. That's a 20% CFM gain! FLOW Pro Compare Data Report ________________________________________________________________________________ No. Date Test Name Manufacturer --- ---------- -------------------- ------------------------- 1 10/22/2009 Both holes WOT Lambo 2 10/22/2009 Backup test #1 Lambo 3 10/22/2009 Small hole WOT only Lambo 4 10/22/2009 Large hole WOT only Lambo ------------------------------------------------------------------- AFTER PORTING 5 11/16/2009 Both holes WOT Lambo 6 11/16/2009 Backup of test #5 Lambo 7 11/16/2009 Small hole WOT only Lambo 8 11/16/2009 Large hole WOT only Lambo ________________________________________________________________________________ CFM Lift No.1 No. 2 No. 3 No. 4 -------- ------- ------- ------- ------- Wide open 681.1 682.8 227.7 464.9 Wide open 808.5 808.4 259.1 539.4 Quote Share this post Link to post Share on other sites More sharing options...
SAMLAMBO Report post Posted November 18, 2009 Thats an extensive rebuilt and I love threads like this, I sure do learn a lot. Thanks and keep us posted. Quote Share this post Link to post Share on other sites More sharing options...
b512m Report post Posted December 2, 2009 Wished I had your skill Limey. If you have plans for a holiday in Bali, do let me know. I can arrange for transport there and I'll get airline tickets and accomodation for you & your family to fly to Jakarta. Perhaps you can teach me and my mechanic how to work on these cars. Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted December 10, 2009 Got my headers and exhaust back from Jetcoat, still waiting on a bunch more parts. Any guesses as to this? Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted December 10, 2009 Very nice! I have no idea what the first part is Quote Share this post Link to post Share on other sites More sharing options...
215mph Report post Posted December 11, 2009 I think it's the panel right behind and above the rear bumper. Quote Share this post Link to post Share on other sites More sharing options...
fcris Report post Posted December 12, 2009 Limey, Any concerns about running headers in these cars with out the insulating shields that are normally around them? Hotter engine compartment, burning leaves and other debris? Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted December 12, 2009 I think it's the panel right behind and above the rear bumper. It is, but is the one for the GT, no bumper slots :-) Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted December 12, 2009 Limey, Any concerns about running headers in these cars with out the insulating shields that are normally around them? Hotter engine compartment, burning leaves and other debris? None at all, i had these on the car for 18 months before i took the car out of commision for the overhaul. I never had them coated before, bare stainless as they came from the factory, decided it was better to coat them for looks and to also insulate them. Quote Share this post Link to post Share on other sites More sharing options...
Zmydust Report post Posted December 29, 2009 Check out the flywheel ring gear, this entire flywheel was machined from aluminium, even the ring gear and after 5000 miles of driving and many a good launch, the ring gear is as perfect as the day it was installed. The suspension parts will be removed once the items listed above are finished and collected from the powder coaters. I don't like doing too many different tasks at once, that way i can be sure to do things correct. The Ring Gear should as it would have nothing to do with launches , correct? I believe it is used solely for the starter. Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted May 2, 2010 Engine coming together, as well as more updates on suspension. Quote Share this post Link to post Share on other sites More sharing options...
RHershey Report post Posted May 3, 2010 Thanks for the update it is looking great. It sure takes a lot of hard work and time to do it. Can't wait to see it done, I'm sure you are are thinking the same thing. Quote Share this post Link to post Share on other sites More sharing options...
TrentS Report post Posted May 3, 2010 Looks great! Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted May 4, 2010 Looking great! Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted May 20, 2010 L/H rear 99% finished. Before & after: Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted May 21, 2010 Awesome!! Quote Share this post Link to post Share on other sites More sharing options...
Allan-Herbie Report post Posted May 21, 2010 Awesome!! Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted May 21, 2010 HOLY COW! Absolute perfection! Absolute beauty! Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted May 21, 2010 wow nice work Quote Share this post Link to post Share on other sites More sharing options...
limey Report post Posted July 12, 2010 Some more candy. Front suspension all done, finishing up right hand rear. Custom made water pump and pulley, 10 rib S/C belt & 4 rib A/C pulley drives off the WP. All custom pulleys for S/C kit. GT Rear body panel installed Engine should be ready to drop in next week. Powder coated all calipers, these we completley strip down to the bare caliper & then PC S/C Intake pipe, with re-circ valve Lift valves rebuilt & refinished Quote Share this post Link to post Share on other sites More sharing options...
emilio Report post Posted July 12, 2010 fabolous worck Quote Share this post Link to post Share on other sites More sharing options...
RHershey Report post Posted July 12, 2010 Dam! That is looking fabulous, you are doing a first class job Quote Share this post Link to post Share on other sites More sharing options...
