murcivu Report post Posted August 25, 2018 Is this normal? Should this be a deal breaker? Quote Share this post Link to post Share on other sites More sharing options...
IanMan Report post Posted August 25, 2018 Search for a thread related to this if you haven't already. I recall a few people referring to this as a common side effect. Remove the glass, clean and polish and reinstall. Good to go. Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted August 25, 2018 Search for a thread related to this if you haven't already. I recall a few people referring to this as a common side effect. Remove the glass, clean and polish and reinstall. Good to go. I have read about it. But having to carefully take apart the lens, that worrisome. Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted August 26, 2018 Never mind. He proceeded with the purchase. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted August 26, 2018 This is on my to-do list, but keeps getting pushed down as I get tied up with other car projects. It's not an easy fix unless you pay someone to do it (around $2K from what I remember of some guy that does it), or fork out $15K to Lambo for new units. Tedious work, but that glass is pretty strong stuff, so unless you do something really stupid, it won't break. Quote Share this post Link to post Share on other sites More sharing options...
JohnN Report post Posted August 27, 2018 There is a specialist guy who just rebuilds Murci headlights. I believe his name is Nick Naylor. Quote Share this post Link to post Share on other sites More sharing options...
whiteout Report post Posted August 29, 2018 I met up with Nick Naylor over the weekend. Super knowledgeable guy on the headlights (and the Murci in general). Definitely shoot him an email if you're thinking about doing anything with the headlights. Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted August 30, 2018 Thanks a bunch guys. I'll pass along the info. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 14, 2018 It’s not for everyone but it’s not impossible. I did just what stimpy said. Pulled off glass, cleaned inside and had the glass professionally polished. Then resealed. Very happy with the results. With elbow grease, I spent less than $50 on all supplies and about $100 polishing the glass. Not bad for a few days work. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 14, 2018 Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted November 15, 2018 Inahi, what was your approach to cutting through the factory glue holding the glass to the housing? It's a tongue and groove design, so it's not clear what's the best way to cut through it. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 15, 2018 Hi stimpy. It’s not actually tongue and grove. It’s just a channel. I used a very thin flexible blade to cut under the weatherstrip. This took the longest. I can send pics. Noncutting at all. Once cleaned, I baked the lense and used Japanese automotive butyl sealer. The blade used is same as one that is used to cult seal on iPhone for glass removal. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted November 15, 2018 2 hours ago, Inahi said: Hi stimpy. It’s not actually tongue and grove. It’s just a channel. I used a very thin flexible blade to cut under the weatherstrip. This took the longest. I can send pics. Noncutting at all. Once cleaned, I baked the lense and used Japanese automotive butyl sealer. The blade used is same as one that is used to cult seal on iPhone for glass removal. Thanks! I bought that "spudger" in anticipation of this job from your recommendation. It looks like this one: https://www.amazon.com/TOOLISESAMO-iSesamo-Electronic-Device-Repair/dp/B00792JJK4/ref=sr_1_4?ie=UTF8&qid=1542257502&sr=8-4&keywords=iSesamo+genuine+spudger+repair+opening+pry+tool Do you have a close up pic of the glass cover from the bottom showing the design of the glass edge where the factory glue is applied? Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 15, 2018 You’re in luck. I happen to have a brand new set of glass. I bought in anticipation of cracking the glass when I tried to separate the assembly. Heres some close up pics. The pic is of glass up side down. As you can see, there’s only a channel where the glass sits and is held in by the seal goos luck !! On 7/3/2018 at 12:52 PM, THIRDGEN said: Got the full kit on classifieds for a great price. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 15, 2018 Yes I used the spudger and a whole lot of patience to get the seal to separate the glass from headlight assembly. Quote Share this post Link to post Share on other sites More sharing options...
porter Report post Posted November 15, 2018 Very common issue with Murcielagos. Quote Share this post Link to post Share on other sites More sharing options...
megachad Report post Posted November 19, 2018 Wow. looks great when finished!! Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 19, 2018 It’s a bit scary at first but since I had new glass, I had a plan B. Luckily I successfully replaced without breaking glass or plastic. Once you do one side. The other side is easier. It still took about 1.5 hours a side to take apart and clean. But well worth the effort since the results are amazing. I hate seeing murcs with fogged up lenses. Makes these awesome machines look old and not well kept I’d volunteer to do them if I had the time. Quote Share this post Link to post Share on other sites More sharing options...
V12noise Report post Posted November 20, 2018 Good job! Did you heat up the whole thing first before cutting in with the spudger, or did you go in at room temp? Quote Share this post Link to post Share on other sites More sharing options...
murcivu Report post Posted November 21, 2018 That turned out fantastic. I'll have to let my friend know about this post. Not sure if I'll be confident enough to tackle this myself if my lens ever fogs up. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 21, 2018 Hi v12. dont know about others, but I didn’t have to heat the assembly. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 21, 2018 I used morimoto butyl seal to attach glass back onto assembly. Worked like a charm. No leaks or fogging. It’s been almost. Year since I did the job. Quote Share this post Link to post Share on other sites More sharing options...
Stimpy Report post Posted November 21, 2018 From my understanding, the original glue for the glass is more of a silicon base that will not soften with heat like other manufacturer's headlight's glue. Also, the headlight housing is not sealed from the atmosphere. It has 5 vent openings at the bottom, so you are not trying to get an airtight seal when putting the glass back on. The glass wraps around the plastic light housing, and then the body wraps around the glass, so water ingress is not an issue. The housing is held from the bottom, and the glass can't be removed from the top so even if the glass came loose it can't go anywhere. The main thing is to glue the glass on so that it's easy to get off again, because this job will likely need to be done again in the future. Quote Share this post Link to post Share on other sites More sharing options...
Inahi Report post Posted November 21, 2018 Good point. I like morimoto because it’s easy to take apart with heat. Quote Share this post Link to post Share on other sites More sharing options...
JanDaMan Report post Posted November 21, 2018 On 11/15/2018 at 6:05 AM, porter said: Very common issue with Murcielagos. If its so common shouldn't it be a factory defect that the dealerships should take care of? Probably not, but I don't know what makes something a manufacture defect or not. Not even sure why this happens on the inside of the glass, maybe heat change from using the lights? Will need to check mine to see if I have it. Its odd, it seems it also takes extensive polishing to remove it. Quote Share this post Link to post Share on other sites More sharing options...
