2007gallardo Report post Posted August 9, 2013 Longest build ever Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 9, 2013 1055060[/url]'] How difficult is it to convert to 6 speed and what about the third pedal? We will time the conversion when we go from manual to egear but it won't take long. And the clutch pedal will swing up and out of the way! Quote Share this post Link to post Share on other sites More sharing options...
Smash Boy Report post Posted August 9, 2013 After seeing this transmission change, gotta admire the balls to do a conversion on a car of this magnitude. Wiggs, you should have bought an Enzo instead, done a manual conversion, and called it a day. You would have been a hero. Quote Share this post Link to post Share on other sites More sharing options...
Jpegs13 Report post Posted August 9, 2013 Thought I would start a new thread that would be sans the nonsense. No chance Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted August 9, 2013 David, will it be on display at the stampede launch? I know it won't run the stampede, that wouldn't make sence. Quote Share this post Link to post Share on other sites More sharing options...
Gentry Report post Posted August 9, 2013 Is there a goal date for this car to be drivable? Quote Share this post Link to post Share on other sites More sharing options...
Rouleur Report post Posted August 9, 2013 David, you have to help me understand something. I know you have touted the NASA connection and it has been flogged to death, blah blah blah. I am not here to bash. I have a question. How does it make sense to run your charge air pipes, that is pushing air that has just been cooled by your intercooler, right next to the hottest component of the car (the Turbo). You are taking air that has just had its temp mechanically dropped and raising it right back up again immediately before combustion. I don't get it. If you look at the Underground kit, they have the intercoolers immediately before the air enters the intake/combustion chamber. I am curious as to why you did this. I do like that there is minimal bending in your intake tubing, to smooth airflow, but it also looks as though it is not symetrical/equal length runners. Would that not give you different pressures side to side? I am asking, as I am curious. Good luck with getting it on the road, it looks as though it has been a mammoth project. Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 9, 2013 1055118[/url]'] David, you have to help me understand something. I know you have touted the NASA connection and it has been flogged to death, blah blah blah. I am not here to bash. I have a question. How does it make sense to run your charge air pipes, that is pushing air that has just been cooled by your intercooler, right next to the hottest component of the car (the Turbo). You are taking air that has just had its temp mechanically dropped and raising it right back up again immediately before combustion. I don't get it. If you look at the Underground kit, they have the intercoolers immediately before the air enters the intake/combustion chamber. I am curious as to why you did this. I do like that there is minimal bending in your intake tubing, to smooth airflow, but it also looks as though it is not symetrical/equal length runners. Would that not give you different pressures side to side? I am asking, as I am curious. Good luck with getting it on the road, it looks as though it has been a mammoth project. We set it up that way because the NASA connection has been with heat shielding materials and shielding the heat of the turbos from the charge pipes is actually quite easy. What we didn't want to do is bake the intercooler with the turbos as that ensures poor efficiency. Also, they are as symmetrical and equal length (within a mm) as the offset engine allows. Quote Share this post Link to post Share on other sites More sharing options...
Destructo Report post Posted August 9, 2013 We set it up that way because the NASA connection has been with heat shielding materials and shielding the heat of the turbos from the charge pipes is actually quite easy. What we didn't want to do is bake the intercooler with the turbos as that ensures poor efficiency. Also, they are as symmetrical and equal length (within a mm) as the offset engine allows. What kind of temps have you seen from testing? Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted August 9, 2013 What kind of temps have you seen from testing? Ambient. Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 9, 2013 What kind of temps have you seen from testing? We had a MAP gas torch on a piece of 2mm material about 3-4" away so most likely something in the 2000° range given MAP gas is 3200° at its hottest and we were seeing 108° on the other side. We were easily able to hold the material in our hands during the test. It was pretty amazing. Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted August 9, 2013 Dave, MAPP gas was actually discontinued 5 years ago. The stuff you get now is just propane with some added goodies. If it's being used with a regular benzomatic propane head without supplemental oxygen you aren't going to be able to heat anything up to much over 900 (I've measured MAPP vs. aceacetylene while heat treating steel). Using anything that has a concentrated heat source like a torch isn't really going to give you a good indication of how well a shielding material will work, since it's designed to dissipate heat from a large area. Until you get eveything buttoned up and actually see where the heat is going due to airflow, radiance, etc. it will all just be speculation. My "ambient" remark was in regards to the fact that the turbos have not seen boost yet. Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 9, 2013 Dave, MAPP gas was actually discontinued 5 years ago. The stuff you get now is just propane with some added goodies. If it's being used with a regular benzomatic propane head without supplemental oxygen you aren't going to be able to heat anything up to much over 900 (I've measured MAPP vs. aceacetylene while heat treating steel). Using anything that has a concentrated heat source like a torch isn't really going to give you a good indication of how well a shielding material will work, since it's designed to dissipate heat from a large area. Until you get eveything buttoned up and actually see where the heat is going due to airflow, radiance, etc. it will all just be speculation. My "ambient" remark was in regards to the fact that the turbos have not seen boost yet. Good info! And yes, you are correct. The real test will be done with a fully running engine. Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted August 9, 2013 You need to get one of these. It works just like a digital camera ( image capture, SD card, and whatnot) and has more features than I've ever needed. Can you tell it's a slow Friday? Great for troubleshooting electrical gremlins like shorted wires also. Just watch out when you are pointing it at females or you may end up in court! Quote Share this post Link to post Share on other sites More sharing options...
HannibalACP82 Report post Posted August 9, 2013 (infrared) laser to the eye! Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 9, 2013 You need to get one of these. It works just like a digital camera ( image capture, SD card, and whatnot) and has more features than I've ever needed. Can you tell it's a slow Friday? Great for troubleshooting electrical gremlins like shorted wires also. Just watch out when you are pointing it at females or you may end up in court! That's awesome. I love TI cameras. Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted August 10, 2013 (infrared) laser to the eye! He'll live. The laser wasn't on (I think) and his eyes were closed. I use infrared laser micrometers all the time and have always wondered just how mutagenic those lasers really are. I guess I'll find out eventually. Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted August 18, 2014 Reviving this thread since Stiggy made it out west part deux. Hopefully we'll see some video of a 300 MPH fly by or some jaunts into the upper atmosphere. I also used my keen powers of deduction to figure out why there have been so many delays. It seems Dave and Co. have been battling that damned Y2K bug this whole time. That, or what you are witnessing in the above pic is the first day in a new millennium of car tuning. The thousand year "Riiiiigggghhhht" . In all seriousness, glad the car is buttoned back up and roadworthy. Must feel great to be driving it again. Now turn up the boost and see what it can do! Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 19, 2014 Put almost 1,000 miles on the car the past 7 days and it feels great! Displaying at Quail was a great honor and looking forward to some more great Cali driving before sending him home! Quote Share this post Link to post Share on other sites More sharing options...
sprite Report post Posted August 19, 2014 Put almost 1,000 miles on the car the past 7 days and it feels great! Displaying at Quail was a great honor and looking forward to some more great Cali driving before sending him home! How much power are you making? Quote Share this post Link to post Share on other sites More sharing options...
Hovik Report post Posted August 19, 2014 How much power are you making? 670? Quote Share this post Link to post Share on other sites More sharing options...
pakisho Report post Posted August 19, 2014 Quote Share this post Link to post Share on other sites More sharing options...
Supercar Ace Report post Posted August 19, 2014 Spotted at the Quail Lodge Quote Share this post Link to post Share on other sites More sharing options...
Kevin2772 Report post Posted August 19, 2014 Totally off topic, but i want to know how the guy from NY has a road registered MC12 Corsa.... Quote Share this post Link to post Share on other sites More sharing options...
D.Wiggs Report post Posted August 19, 2014 The MC12 is owned by Beverly Hills Motoring. We have it tuned on low boost, 91 Octane so it's 'only' making about 1200rwhp. Even with 5lb. Springs we couldn't make less than 1000! LOL Great shot at Quail! Quote Share this post Link to post Share on other sites More sharing options...
