dtrax Report post Posted July 28, 2009 That actually looks quite good I'm going to a dinner do at the factory at the start of September to see the real car http://www.autoexpress.co.uk/news/autoexpr...458_italia.html Quote Share this post Link to post Share on other sites More sharing options...
dtrax Report post Posted July 28, 2009 http://www.hrowen.co.uk/Ferrari/News-and-O...458-Italia.aspx Maranello, July 28th 2009 While it’s true that every Ferrari is innovative by definition, it’s equally true that in the course of the Prancing Horse’s history, certain cars have marked a genuine departure from the current range. This is very much the case with the Ferrari 458 Italia, which is a massive leap forward from the company’s previous mid-rear engined sports cars. The new model is a synthesis of style, creative flair, passion and cutting-edge technology, characteristics for which Italy as a nation is well-known. For this reason Ferrari chose to add the name of its homeland to the traditional figure representing the displacement and number of cylinders. The Ferrari 458 Italia is a completely new car from every point of view: engine, design, aerodynamics, handling, instrumentation and ergonomics, just to name a few. A two-seater berlinetta, the Ferrari 458 Italia, as is now traditional for all Ferrari’s road-going cars, benefits hugely from the company’s Formula 1 experience. This is particularly evident in the speed and precision with which the car responds to driver inputs and in the attention focused on reducing internal friction in the engine for lower fuel consumption than the F430, despite the fact that both overall displacement and power have increased. However, Ferrari’s track experience makes its presence felt in the 458 Italia not only in terms of pure technological transfer but also on a more emotional level, because of the strong emphasis on creating an almost symbiotic relationship between driver and car. The 458 Italia features an innovative driving environment with a new kind of steering wheel and dashboard that is the direct result of racing practice. Once again input from Michael Schumacher - who was involved from the very start of the 458 Italia project - played an invaluable part. The Ferrari 458 Italia’s Pininfarina design provides further evidence of the complete departure from the past that this new car hails. The Ferrari 458 Italia has a compact, aerodynamic shape, underscoring the concepts of simplicity, efficiency and lightness that inspired the project. As with every Ferrari, the car’s styling has been very heavily influenced by the requirements for aerodynamic efficiency, as can be seen from the downforce of 140 kg at 200km/h generated by the new model. The front features a single opening for the front grille and side air intakes, with aerodynamic sections and profiles designed to direct air to the coolant radiators and the new flat underbody. The nose also sports small aeroelastic winglets which generate downforce and, as speed rises, deform to reduce the section of the radiator inlets and cut drag. The new 4499 cc V8 is the first Ferrari direct injection engine to be mid-rear mounted. It has a very low piston compression height typical of racing engines which contributed to achieving its compression ratio of 12.5:1. Equipped with the traditional flat-plane crankshaft, the engine delivers 570 CV at 9000 rpm and, with an outstanding power output of 127 CV/litre, sets a new benchmark not only for the whole Ferrari range and the history of company, but also for the entire market segment. Maximum torque is 540 Nm at 6000 rpm, over 80 per cent of which is available from 3250 rpm. Specific torque is a record 120 Nm/litre. However, what is truly extraordinary is the amount of torque available while still maintaining high levels of power at low revs. The car’s soundtrack is also typical Ferrari, with an exciting, powerful growl emerging from the engine before it channels through to the exhaust’s three rear tailpipes. The 458 Italia is equipped with the seven-speed dual-clutch transmission which increases performance whilst providing very smooth shifts even at full throttle. The engineers have developed specific, sportier gear ratios to match the power and torque curves of the new V8, guaranteeing high torque even at lower engine speeds and allowing the car to reach its maximum speed in top gear. This new Ferrari is also a major leap forward when it comes to cutting emissions. Despite the fact that the new engine is significantly more powerful than the V8s that preceded it, the Ferrari 458 Italia produces just 320 g/km of CO2 and fuel consumption is 13.7 l/100 km (combined cycle), the best in the entire segment. The engineers also focused on weight reduction during the design phase for similar reasons. Consequently, the Ferrari 458 Italia has a dry weight of 1380 kg with a power-to-weight ratio of 2.42 kg/CV. Weight distribution is also optimal with 58 per cent over the rear axle. The result of the engineers’ endeavours can be summed up in to two simple statistics which together perfectly encapsulate the Ferrari 458 Italia’s exceptional performance: 0-100 km/h acceleration in under 3.4 seconds and a maximum speed in excess of 325 km/h. For the new chassis, once more in aluminium, Maranello’s engineers incorporated various types of advanced alloys along with aerospace industry-derived manufacturing and bonding techniques. With regard to vehicle dynamics, the Ferrari 458 Italia’s suspension features twin wishbones at the front and a multi-link set-up at the rear tuned for maximum roadholding and superlative handling. Along with a more direct steering ratio, the 458 Italia thus offers extremely rapid turn-in and body control whilst maintaining superior ride comfort. The integration of the E-Diff and F1-Trac (now controlled by the same ECU) and their respective mappings is even greater, resulting in a 32 per cent increase in longitudinal acceleration out of corners compared to previous models. The evolution of the control logic, with even faster and more accurate calculation of levels of grip, ensures even greater roadholding, better handling and ease of control on the limit. The same ECU also governs the high-performance ABS, providing even more precise control over the logic threshold and greater efficiency. The brakes also feature a prefill function whereby the pistons in the callipers move the pads into contact with the discs on lift off to minimise delay in the brakes being applied. This combined with the ABS has cut the 100-0 km/h braking distance to a mere 32.5 metres. The Ferrari 458 Italia’s interior is another area of the car that exalts its sporty personality. The driver is welcomed by a new layout and a revolutionary ergonomic interface where the main controls are all clustered on the steering wheel. With the Ferrari 458 Italia, Maranello has brought a highly distinctive new car to its 8-cylinder range. The company now offers two models that share a common, race-derived DNA, both exceptionally sporty and fun to drive in true Ferrari tradition, but aimed at two very different kinds of client. While the Ferrari California was created for owners requiring a more versatile sports car with a practical edge, the 458 Italia is designed for owners for whom the priority is uncompromising on-road performance with occasional track day capability, but who still demand a car that is useable in day-to-day driving like all Ferrari’s recent models. Ferrari 458 Italia – Technical specifications Dimensions Length 4527 mm (178.2 in.) Width 1937 mm (76.3 in.) Height 1213 mm (47.8 in.) Wheelbase 2650 mm (104.3 in.) Dry weight 1380 kg (3042 lbs)* Weight/power ratio 2,42 kg/CV (7.16 lbs/kW) Weight distribution fr/r 42%/58% Engine Type V8 – 90° Displacement 4499 cc (274.5 cu in.) Maximum power 570 CV (425 kW)** @ 9000 rpm Maximum torque 540 Nm (398 lbs/ft) @ 6000 rpm Specific power output 127 CV/l Compression ratio 12.5:1 Tyres Front 235/35 ZR20 8.5” Rear 295/35 ZR20 10.5” Performance Maximum speed >325 km/h (>202 mph) 0-100 km/h <3.4 s Fuel consumption + emissions Fuel consumption*** 13.7 l/100 km Emissions*** 320 g CO2/km Gearbox Dual-clutch, 7-speed F1 Electronics E-Diff3, F1-Trac, high-performance ABS * With forged wheels and Racing seats ** Including 5 CV of ram effect *** Combined cycle (ECE+EUDC) Quote Share this post Link to post Share on other sites More sharing options...
Mr. Vroom Report post Posted July 28, 2009 That actually looks quite good Yes it does! Quote Share this post Link to post Share on other sites More sharing options...
Fortis Report post Posted July 28, 2009 I like it, except the three pipes! Quote Share this post Link to post Share on other sites More sharing options...
Basstones Report post Posted July 28, 2009 Wow, much nicer shape than previous models. Will be interested to see real pictures Quote Share this post Link to post Share on other sites More sharing options...
intence Report post Posted July 28, 2009 is this the f430 replacement? Quote Share this post Link to post Share on other sites More sharing options...
Ecnelis Report post Posted July 28, 2009 Interior: Quote Share this post Link to post Share on other sites More sharing options...
Kevin2772 Report post Posted July 28, 2009 Curious looking. The 3 tails kind of pays hommage to the F40. Ill reserve judgement until the real version is released. But why 458? why not 450? what I dont like are the california style tail lights. Quote Share this post Link to post Share on other sites More sharing options...
Lambo Guy Report post Posted July 28, 2009 Curious looking. The 3 tails kind of pays hommage to the F40. Ill reserve judgement until the real version is released. But why 458? why not 450? what I dont like are the california style tail lights. My guess is 4.5L + 8 Cylinders... just like how the 328, 348, etc. were named... Quote Share this post Link to post Share on other sites More sharing options...
Rouleur Report post Posted July 28, 2009 Hmm, I kinda like it actually. Thing looks like it is going to be a monster in the performance category. Should be interesting. Quote Share this post Link to post Share on other sites More sharing options...
Iceman Report post Posted July 28, 2009 Not bad at all... definitely takes some design ques from the Lotus Evora, but in effect, most 'organic' designs have to start looking similar at some given time. I'm sure the performance won't disappoint.... Soooo, what's Lambo working on to counter?? I know the Lotus Esprit replacement is due out for 2012, and probably will be using a Lotus tuned version of the light Lexus LF-A V10. Quote Share this post Link to post Share on other sites More sharing options...
Lambo91 Report post Posted July 28, 2009 kinda like the side profile..but thats all..haha Quote Share this post Link to post Share on other sites More sharing options...
intence Report post Posted July 28, 2009 360 is still the best looking modern ferrari imo. Quote Share this post Link to post Share on other sites More sharing options...
Lambo91 Report post Posted July 28, 2009 360 is still the best looking modern ferrari imo. 360CS is the best looking modern ferrari till now. now i think the 458 looks like the Artega GT Quote Share this post Link to post Share on other sites More sharing options...
kane00 Report post Posted July 28, 2009 I like it. A lot. 9000 rpms! Its going to be a blast to drive. This is the kind of product and technology that can be brought to the market when the company has big dollars behind them. Quote Share this post Link to post Share on other sites More sharing options...
rampante Report post Posted July 28, 2009 "....Kinda looks like the Evora?" That is an understatement !! Quote Share this post Link to post Share on other sites More sharing options...
lambornima Report post Posted July 28, 2009 the front is hideous but I like the back and side! time for an LP560 vs F458 race! Quote Share this post Link to post Share on other sites More sharing options...
Assman Report post Posted July 28, 2009 I like the back and sideviews. It's much better than the 430 for sure. Quote Share this post Link to post Share on other sites More sharing options...
Luxeous Report post Posted July 28, 2009 that thing is sick, reminds me of the Enzo. Quote Share this post Link to post Share on other sites More sharing options...
jota Report post Posted July 28, 2009 Looks familiar... Quote Share this post Link to post Share on other sites More sharing options...
Kevin2772 Report post Posted July 28, 2009 Damn Jim...I guess you could say imitation is the greatest form of flattery? And is that pic from your new garage? Quote Share this post Link to post Share on other sites More sharing options...
jota Report post Posted July 28, 2009 Damn Jim...I guess you could say imitation is the greatest form of flattery? And is that pic from your new garage? Hi I guess. No that is the garage at Villa d'Este. Here's a web cam capture of my new garage. Quote Share this post Link to post Share on other sites More sharing options...
Mako Report post Posted July 28, 2009 Wow, and here I thought they couldn't get any worse. Absolutely awful. Not one design element is even slightly appealing on the car from any angle. It looks even more Japanese in heritage than the Enzo, which I didn't think was possible. Can't believe some of the people commenting positively on it in this thread, clearly there are F-car blinders on a bit. If it was sourced from Hyundai, or Lamborghini for that matter, our veterans would be screaming bloody murder. Ferrari/Pininfarina of the 90s is clearly dead...we're never going to get another balanced beauty like the 355 past this point. Instead the bizarre look of the Enzo/599 continues, only now spiced up with a bit of overly soft R8 cues. What a shame. Quote Share this post Link to post Share on other sites More sharing options...
fastlane Report post Posted July 28, 2009 It looks OK but not spectacular for a new car, but Lambo better learn how to drop weight real fast or it will get its ass kicked. F keeps adding power without adding weight. Quote Share this post Link to post Share on other sites More sharing options...
Mako Report post Posted July 28, 2009 It looks OK but not spectacular for a new car, but Lambo better learn how to drop weight real fast or it will get its ass kicked. F keeps adding power without adding weight. You, nor anyone else, has a clue what the true weight of this car is. "Dry" weights aren't worth the paper they're published on. We won't know the true figure until someone puts a press car on a scale. Quote Share this post Link to post Share on other sites More sharing options...
