Lambofan35 Report post Posted November 6, 2014 I have had my Twin Turbo Gallardo for about 2.5 years that was originally built for the late Ray Hofman (RIP) by Underground Racing. The car has been great and street driven a LOT. I know this car front to back and have put in the time to learn everything I can and its been great to me! My goal has always been to keep this a street car but make it better So this time I decided to explore making a Custom Billet Carbon Ceramic Brake Kit for ANY YEAR Gallardo that original was NON Carbon Ceramic Brakes. This kit uses the Factory Brake Calipers, brake lines, master cylinder, etc. The only parts needed to make this kit work are: New Rotors, New Pads, and hardware. Front Kit Pictured on my car: 380mm x 34mm on Billet Aluminum hardware. Front Kit options: 380mm, 390mm, 398mm, 405mm Price: I will offer a kit if I get enough interest. Front Kit weight savings: 27lbs stock 365mm Gallardo rotor my Billet CCB rotor is 11lbs OEM CCB Rotors weigh about 14lbs FYI. 380mm Girodisc 2 piece rotors=18lbs 16lbs x2= 32lbs rotating weight savings for the front kit only compared to steel Gallardo brakes. Rear Kit: It is still being developed as I need a bit more fabrication parts for the e-brake since I wanted to keep it. My rear Kit should be about 350mm or so and weigh 9lbs. Steel Gallardo rotors are 20lbs OEM CCB rotors are 11.75lbs FYI. Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted November 6, 2014 BIG TIRE Conversion Everyone always has issues with running too big or too small tires on these cars with front differential overheating. I did a lot of calculations and ordered some custom 19" barrels from HRE to see what is the MAX width I can run. Conclusion on my widebody 19x13" with Swift aftermarket coilover springs, and a 345/30/19. You CAN NOT run any wider tire/wheel on a Gallardo unless you go wider in the back then me which is unlikely, lol. I just put this on today and have put enough miles on it to confirm there is no issues but if my math is right, I'm on the edge of making this work. Any more narrow wheel or taller tire, it wouldn't work right. There is literally so much grip even over my 335/30/18's its not even funny. The old ones were great but these are just glue. Pictures are while I was corner balancing the car and its a lower now. The stack wheel picture is a the fronts at 19x9.5" and 235/35/19 if that gives you an idea of how massive these rear wheels are. Old Rear Tire Setups: 325/25/20 Michelin PS2 315/25/20 Michelin Sport Cup tires 335/30/18 Toyo R888 New Tire Setup: 345/30/19 Toyo R888 Quote Share this post Link to post Share on other sites More sharing options...
Chipster Report post Posted November 6, 2014 Hot! Quote Share this post Link to post Share on other sites More sharing options...
2007gallardo Report post Posted November 6, 2014 that rear tire rub? Yours is a widebody kit right? If so too bad for the non widebody cars. I'd like to put on a full set of 4x4 drag radials....like the GTR's....mainly to piss off Kevin. Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted November 6, 2014 that rear tire rub? Yours is a widebody kit right? If so too bad for the non widebody cars. I'd like to put on a full set of 4x4 drag radials....like the GTR's....mainly to piss off Kevin. LMAO...to piss Kevin off. Its within 1/4 inch of the spring on the inside and very even with the outside fender. Doesn't rub as I run stiffer springs in the rear and the tire goes up to the inside when it compresses anyhow. Maybe rub a little, we will see with more miles. Widebody by an extra couple inches on each side. Maybe 2" I think. Quote Share this post Link to post Share on other sites More sharing options...
VentadorGER Report post Posted November 6, 2014 Are regular 19" wheels large enough for 390mm front brakes? Quote Share this post Link to post Share on other sites More sharing options...
Rouleur Report post Posted November 6, 2014 He is using the stock caliper and I don't see a mention of new mounts for it, so I would imagine that it would work. Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted November 7, 2014 Are regular 19" wheels large enough for 390mm front brakes? Some of the 19"s will fit up to 398mm but that is the limit and would require a certain clearances or wheel type. Ferrari Scuderia wheels are 19" and fit 398mm. I'd say the safe limit on a 19" aftermarket wheel would be around 390mm as the 398mm was just too close on my HRE 19". Quote Share this post Link to post Share on other sites More sharing options...
AudiBull Report post Posted November 7, 2014 Nice! Noticed that the post detailing the new tire setup was your 888th. Very fitting, in more ways than one. Quote Share this post Link to post Share on other sites More sharing options...
shadowzz Report post Posted November 7, 2014 Also the weight saved with the rotors will make the car more nimble. Will definitely see a difference and if not , it will act with the biggest tire/wheel setup (19") as if the setup was 1 inch lower (18") Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted November 7, 2014 Are regular 19" wheels large enough for 390mm front brakes? I have 390 mm Alcon steel race rotors on my front and calipers just clear my oem 19" rim by 2 mm, with minor scraping on inside of rim. some slight grinding on the back of caliper to remove raised logo cured the scraping problem. Strangely enough, miniscule caliper clearance on my OZ Superleggera 19" rims, but calipers did not scrape inside of rim as slightly different offset to oem rims. Probably accounts for the OZ Superleggera rims with Michelin PSS scraping on the fender liners on full lock. cheers, john Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted November 7, 2014 that rear tire rub? Yours is a widebody kit right? If so too bad for the non widebody cars. I'd like to put on a full set of 4x4 drag radials....like the GTR's....mainly to piss off Kevin. You mean just like the Alpha lambda lambda lambda and the lambda lambda lambda and the omega mu mu GTR35 that won Texas Invitational and just ran 7.7 sec and 186 mph on the quarter mile with street tyres-not! http://blog.caranddriver.com/watch-2000hp-...nds-at-186-mph/ cheers, john Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted November 7, 2014 Well I'm not trying to go 4x4 like those GT-R's but I going from a 335/30/18, I had to raise the rear maybe 1/4". It's still a lot lower than 90% of Gallardos. Here is a picture of the car corner balance at 49.9% and 50.1%, 57.3% weight bias in the rear still and rolling on 345/30/19 R888's without a problem. Quote Share this post Link to post Share on other sites More sharing options...
emanon Report post Posted November 7, 2014 Now if only you could get some 315's up front. Looks bad ass! Quote Share this post Link to post Share on other sites More sharing options...
duhawks Report post Posted November 7, 2014 Well I'm not trying to go 4x4 like those GT-R's but I going from a 335/30/18, I had to raise the rear maybe 1/4". It's still a lot lower than 90% of Gallardos. Here is a picture of the car corner balance at 49.9% and 50.1%, 57.3% weight bias in the rear still and rolling on 345/30/19 R888's without a problem. That looks sweet! Quote Share this post Link to post Share on other sites More sharing options...
shadowzz Report post Posted November 7, 2014 can you hook fullboost in 2nd with this tire/wheel setup ? Quote Share this post Link to post Share on other sites More sharing options...
2007gallardo Report post Posted November 7, 2014 You mean just like the Alpha lambda lambda lambda and the lambda lambda lambda and the lambda lambda lambda and the lambda lambda lambda and the omega mu mu mu mu GTR35 that won Texas Invitational and just ran 7.7 sec and 186 mph on the quarter mile with street tyres-not! http://blog.caranddriver.com/watch-2000hp-...nds-at-186-mph/ cheers, john Lol yeah. Whatever would piss off Kevin at Ugr. Btw I was at TI and won the 6 speed manual class. Quote Share this post Link to post Share on other sites More sharing options...
pockmark Report post Posted November 8, 2014 Nice! I am considering putting that same rear tire on my Z Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted November 8, 2014 Lol yeah. Whatever would piss off Kevin at Ugr. Btw I was at TI and won the 6 speed manual class. Hi 2007 Gallardo, Congrats on a great win. I loved your enthusiastic response at the win jumping on the roof I still have a soft spot for the manual Gallardo. cheers, john Quote Share this post Link to post Share on other sites More sharing options...
Steve K Report post Posted November 9, 2014 wow ! great post. anymore info on the brakes ? thats just awesome. also, what tire size are you running up front? Quote Share this post Link to post Share on other sites More sharing options...
Lamboperth Report post Posted November 11, 2014 He is using the stock caliper and I don't see a mention of new mounts for it, so I would imagine that it would work. I don't know about the ceramic kit above, but if you are fitting 390 mm front rotors , you do need spacers to retain the original calipers. You can see the spacers on this R8 V10 big brake 390 mm upgrade that I installed on my LP560-4. See this link http://www.another board/vbforum/f4...nstalled-61386/ cheers, john Quote Share this post Link to post Share on other sites More sharing options...
SV-N-IT Report post Posted November 11, 2014 looks great Nick! Quote Share this post Link to post Share on other sites More sharing options...
Lambofan35 Report post Posted November 11, 2014 Thanks guys. The front CCB kit I have here does require billet spacers which is a small part of the kit. The front tires are 235/35/19 R888 which is pretty normal for the Gallardo. Its the best size without rubbing or throwing stuff out of balance. Its not big but its very similar to how the Ford GT is setup with a small tire up front and they go 250-270mph in the mile, lol. I just did a little testing and between the bigger tire and lighter rotors up front (back is still 2 piece giro rotors for now). I was able to get a 3.39second VBOX on regular 93 octane and a full tank of gas for the 100mph-150mph with 0% slope. If that isn't the pump gas record even for the 2R UGR cars then it's darn close, right HoustonT? Quote Share this post Link to post Share on other sites More sharing options...
RIPPERTT Report post Posted November 11, 2014 Well I'm not trying to go 4x4 like those GT-R's but I going from a 335/30/18, I had to raise the rear maybe 1/4". It's still a lot lower than 90% of Gallardos. Here is a picture of the car corner balance at 49.9% and 50.1%, 57.3% weight bias in the rear still and rolling on 345/30/19 R888's without a problem. Car Looks AMAZING !!!! Great Job Man !! Quote Share this post Link to post Share on other sites More sharing options...
duhawks Report post Posted November 11, 2014 Thanks guys. The front CCB kit I have here does require billet spacers which is a small part of the kit. The front tires are 235/35/19 R888 which is pretty normal for the Gallardo. Its the best size without rubbing or throwing stuff out of balance. Its not big but its very similar to how the Ford GT is setup with a small tire up front and they go 250-270mph in the mile, lol. I just did a little testing and between the bigger tire and lighter rotors up front (back is still 2 piece giro rotors for now). I was able to get a 3.39second VBOX on regular 93 octane and a full tank of gas for the 100mph-150mph with 0% slope. If that isn't the pump gas record even for the 2R UGR cars then it's darn close, right HoustonT? That is 100% the record for pump gas 100-150. Mine is like 3.7-3.9 on pump with 1 shift. Crazy you can do it with out a shift. Quote Share this post Link to post Share on other sites More sharing options...
